OC455
- Joined
- Apr 20, 2018
- Posts
- 3,326
- Reaction score
- 3,018
- Location
- Central NY
- Ram Year
- 2018, 2019
- Engine
- 5.7 Hemi Big Horn, 6.4L Hemi 3500 Longhorn Mega cab
Decided awhile back ago, I was tired of borrowing neighbors and friends pressure washers. Either one of the two pressure washers I borrowed were at least 1700psi washers, one a Lowes brand and the other a Harbor Frieght. Both worked well.
Saw that Home Depot was selling Ryobi electric pressure washer and decided to look into those. I purchased the small portable model, 1600psi with a 1.2gallon rate. What the hell, $97 plus $30 for the Ryobi foam cannon/dispenser.
I used Meguiars wash and wax in the foam cannon. I used quite a bit of the Meguiars in the foam blaster. I like the pressure it has and it works very well. They have the "turbo" nozzle which sprays in a pulsating circular pattern and it works very well too. I will say that it seems as if it has a but more pressure than 1600psi compared to the other ones I used.
I think the results speak for themselves as far as how well the pressure washer perforned.
There was a lot of bugs spatter and residue that got removed. The Bighorn needs a bit of professional attention as I found a dent on the drivers side A pillar up high. Have no idea how it got there. Found a small mark on the door and dont know where that came from either.
There is a place here that does some phenomenal vehicle detail work and going to see what he can do to clean up the Bighorn completely. See if there is a shop that can do the paintless dent removal in the area.
