Weight distribution
iam_canadian22
northern ontario
Hey guys i have a question about weight distribution hitches but regaring the trailer not the truck. Ive got a flat deck car hauler that i use for my sxs and from time to time i load a couple extra atv's. When i add the extra atv's id like to use a weight distribution as it makes the trailer tongue heavy. Problem is its a c channel frame and one side houses the brake controler and trailer wiring jb so my current setup doesn't work with these in the way. Any out there that are compatible?
Sent from my SM-G960W using Tapatalk
cyclepuck
2014 2500 Mega
So the brake box is in the way of the hitch frame bracket?
Sent from my SM-G965U using Tapatalk
Anyway to relocate the trailer brake stuff on the trailer? I'm guessing it's probably just your breakaway switch and/or battery, both of which you can relocate.
iam_canadian22
iam_canadian22
northern ontario
Ya its the battery and the wiring jb. I'll have to take a closer look to see if it can be moved without doing a bunch of wiring.
iam_canadian22
iam_canadian22
northern ontario
Yes, i recall seing brackets that were compatible with this situation but dont recall where
Raadz
