What are these?
gixxer
SK Canada
4.7L
Hey everyone,
I hope someone can shed some light on this.
What are these? I believe they are shims.
I was underneath the back end facing the front and I pulled these from between a gap of sheet metal under the bed above the rear axle. I had to drop the spare tire.
There appeared to be a C type notch on the lower piece of metal and a hole in the above part and these shims are in between loose.
Should they be loose or bolted in?
Any help would be greatly appreciated.
I’ll try and get a photo of where I pulled them from.
The truck was rear ended and the body shop took the bed off the truck so I’m hoping they didn’t mess something up.
MADDOG
Living in a Firepit
Yes, those are shims. They fit between a body panel and a frame, or between suspension pieces, etc...and are held in place sandwiched between the two pieces they are designed to keep separated.
As to which shim, can't say but I suspect between the truck bed and frame.
Give the body shop the shims. They'll figure it out. I don't think they messed anything up. Shims are made to be removed and re-used.
gixxer
gixxer
SK Canada
4.7L
Turns out, they were for a 5th wheel and had no need to be on the vehicle.
