What are you towing????
Gregory McKinley
Navy Badge
Piedmont, SC
5.7 E-torque
I pull a 2022 Jayco Flight 28 ft travel trailer using a 10k anti-sway/weight distribution system. Have made several trips from Greenville, SC to Gulf Shores Alabama and Pensacola. My truck has basically the same setup that yours has. Just eats up the fuel. Pulls great on the interstate and on the back roads. Take it to a lot of local campgrounds and in the mountains. Just hit 72 k on my truck. Keep the fluids changed and running BFG KO2s. Loving it!!! Trans, Oil and water temps have been holding normal during mid summer trips. Love that damn Truck.
Ted67
Troy, Idaho
2025 Grand Surveyor 220RBLE...
Set up the Anderson Hitch today. Seems very stable!
I have the Anderson Hitch and a trailer very similar to the one in your photo. No problems at all when it comes to towing.
WSix
S. Illinois
I’m really looking forward to heading out next week!
chaosh1
Had alot of fun with this.. 10k lbs
nlambert182
Huntsville, AL
Started with this behind a 2005 Avalanche & 2005 Expedition: (30', 7,800 lbs)
Did something real stupid and jumped up to this and my 2500: (42', 17k lbs)
Then this: (31', 12k lbs)
To this: (34', 11k lbs)
To this: (43', 16.4k lbs)
To this currently: (33', 9,800 lbs)
WSix
S. Illinois
On our way back home. The hitch works as advertised. It's worked out well...the truck, not so much!
It's strange, just a month ago I stopped at this RV park on our way to Gulfport and discovered the oil filter gasket leaking.
This time, heading back home, again while unhooking the trailer, I noticed splattering on the front of the trailer again.
I checked undernieth, and found the transfer case covered with gear oil.
I have no idea where it's coming from.
The dealership service dept is booked out to April, but the oil and lube dept also does repair work and they will take a look at it and we'll go from there....
DA67Goatman
Ohio USA
Made a 550mile round trip for fence posts.
