Blkngld
- Jul 28, 2015
- 31
- 37
- Location
- Central Jersey
- 2015
- Hemi 5.7
Thanks for that link. I'm going to see if there is a way I can tap into a fuse box somewhere. Maybe I can use something like this : Nilight Fuse Holder Add-a-circuit Fuse TAP Adapter Mini ATM APM Blade Fuse Holder - 10 Pack, 2 years Warranty https://www.amazon.com/dp/B0742BZXC2/ref=cm_sw_r_cp_api_nPmmBb3ZPQ46H
Yes, it's a RHD in Kalgoorlie Australia.
Tuff bullbar and brush rails combo.
www.tuffbullbars.com.au
Custom roll bar (headache rack), 5" turbo back afe power exhaust, tuned by drd.
Dobinson coils all round, front +100kg, 2" level and rear +250kg.
Bilstein 5100 all round.
It's a work vehicle and tows a tri axle trailer doing vehicle delivery and recovery as well as hot shots.
Bull bar is essential out here, probably hit over 100 kangaroos and a baby camel so far.
Sent from my CLT-L29 using Tapatalk
Omg... You will love that!!!!
I like to ramp it up and watch my wife's face when she hops in to drive it. Money well spent!!!
Assuming your truck has the same fuses as mine, a 2014, you'll need a Micro ATM tap, not the Mini, but otherwise it should work.
-K
I do have a 2014. I tried looking at the fuse box under the hood, but it was getting dark and hard to make out what was what. The fuses are tiny, I did realize that.
Any idea which fuses to tap in to for the turn signals and the entry lights? Obviously, I'm not very good at this.
Ah, Sorry, I didn't catch what you wanted to do with them. I'm afraid you're out of luck there. There are no specific fuses for either of those. They are on fuses that handle power to many things, but the actual switching on/off them is in the BCM, it's not something you can tap at the fuse for an add-on like the side lights.
A couple fuses that might be useful to you:
F79 - Clearance Lights - For reasons unknown, this is present and powered even on 1500s and can be tapped. I use it for my air damn lights and plan on using it for the running portion of the side lights. It goes on with the running lights.
F81 - Trailer Right Turn & Brake.
F53 - Trailer Left Turn & Brake.
If you don't want to run wires up from the rear you can tap these at the TIPM (aka fuse box). But the issue with F81 & F53 is that you still need to separate the brake and turn functions to use them with the side lights. Otherwise the turn signal portion will illuminate with the brake lights.
The only way I know of to tap the courtesy lights is to bring the wires into the cab and tap either the front or rear footwell lights or (and I'm less certain about this one's ability to handle the load) the side mirror courtesy lights (aka puddle lights or entry lights).
On older 4th Gen trucks (2009-2012) I have read that you could safely tap the running and turn signal wires to the headlight, but on 2013+ you end up with can-bus errors if you do. Hence my plans to use the F79 Running light circuit and the trailer turn signals (with a separator). Both of my trailers are all LED lighting so the additional load on the circuits will not cause a problem for me.
I'm trying to get my side lights (Recon Big Rig Ice) installed this week, I plan on doing a write up on it to post in the DIY section here.
-K
Was looking at mufflers online and could not decide what I want, ended up going to the store and picked up a K&N drop in filter, definitely gives a bit of a growl but now I really want a new muffler. Also have an AEM filter on the way will try that out too, whichever one I don’t keep will end up with my father in laws’ express.
Borla XS pro
So looks like outer tie rods need to be replaced. Question. Is what about the inners. Should I just replace both only 200 in parts have to see how much for install.
Sent from my SM-N920P using Tapatalk
How does the Borla XS Pro sound with our MDS? Does it sound like crap once the MDS kicks in?Borla XS pro
^^This. Get it done while it's taken apart.IMHO--yep--but I'm sort of cautious anyway--an ounce of prevention is worth a pound of cure----
Jay
Did the Kicker 6 speaker (doors and dash tweeters) upgrade on my 1500 with 5.0 radio. Much better sound and range over OEM.
2017 RAM 1500 CC, LoneStar, Black Pearl
