Socalramfan
Huntington Beach
2011 Big Horn
Is the hood the sports hood?
No, it’s the standard hood.
If I had the Sports one on, I would have probably kept that and make the vents functional.
Initially that was my plan, until I came across the 2500. Got everything I needed from the same vehicle, so I knew it all matched up.
In addition, it was the correct color :waytogo:
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
Oh you scored then lol .. I am always on the lookout for a color matched sports hood for my truck lol ... so far no luck haha!
2018 2wd
If I find a standard hood for less than $100 in good shape, I would grab it and fabricate the scoop or scoops on it with some fiberglass, a buddy and I a few years ago made one for a Silverado and it came out nice, you couldn't even tell it was added on there and it was fully functional ...
Socalramfan
Huntington Beach
2011 Big Horn
Ever so often one pops up, but you do have a rare color. Dont think I’ve ever seen one with it….. would look great on yours :waytogo:
metalchewy
Las Vegas
2010 TRX4
4.7L
Sitting a little squat at sunrise.
Picked up about 1/2 cord from the neighbor today.
hunterdan
SE PA
2019 classic
Just installed the V6 e-fan. Took some effort getting the clutch fan off, everything else was easy. Still need to re-route the wiring so the thermistor can be located on the shroud like it's supposed to.
Bbroj
North Carolina
I've got that same problem here, keeps ****** snowing!
-K
Designed and 3D printed a tissue box holder
Pretty non-invasive, no screws or glue just two tabs that slide under the little console but it stops the tissues from rolling back and forth.
View attachment 399128View attachment 399129View attachment 399130View attachment 399131
Do you sell these? I have the same issue, cant seem to find one of those old cassette/ CD floor organizers that will hold a "cube" tissue box.
MartyZ
Lake Orion, MI
2500 5.7l Hemi
Ordered some new Meats just in time for stick season.
Went with the same size since making 37's fit was a task I didn't want to have done for no reason.
37x13.50 Ironman M/Ts. Set of 4 was $1158, Tire shop near me will mount them all for $100 and balance them.
Final Cost: $1258
I have heard nothing but good things from these tires when used on a solid front axle setup. A buddy of mine is on his 4th set, said hes getting 50-60k out of them and would happily order a 5th set when needed.
Ill give updates once they are mounted and include a couple of pictures :cool:
danielmid
Southeast WI
2015 Sport 4x4
Moved to a snow area that uses salt so I'm looking at undercoatings, add this to the list of things I took for granted living in the desert.
Likely going to go with the NH Oil from a local shop here for both the Ram and the Durango.
odinjunior
Az
I had Load Lifter 7500 XL air bags installed yesterday. They should help get rid of the squat when the RV is hooked up...
2018 2wd
Final Cost: $1258
Good luck with those tires @MartyZ .... I have seen nothing but bad things about them, they don't balance good, wear out fast and have separation issues
I was actually considering them when I lifted my truck, but the shop owner wouldn't even order them for me lol ... working at big o tires we had nothing but issues with the ironmans, I wanted them to save a few hundred bucks but honestly I am super glad I didn't get them ...
Socalramfan
Huntington Beach
2011 Big Horn
Final Cost: $1258
That’s some serious meat on there. How long did your current set last you?
Bandit517
That Trials Guy
Wauseon, OH
Final Cost: $1258
Definitely got your monies worth out of the other set. LOL When my Gladiators are finally ready for replacement I think I'm going to make the step to 37's with the prerunner style fenders and whatever trimming end up being necessary.
Bandit517
That Trials Guy
Wauseon, OH
Looking forward to it.
Im tossing around the idea of doing an amber halo / angel eye, or similar around the housings idea.
Something about amber against black that I like.
Also starting to dig these hoods. Might be too much of a hood thing though. :waytogo:
Instead of green.. Amber,
few ideas for hood / scoop….
I keep looking at hoods too. I've got the standard hood on mine. And with the Vararam I wouldn't hate a center scoop the was (or could be made) functional. I keep bouncing back and forth between these 2.
Socalramfan
Huntington Beach
2011 Big Horn
I like the 2nd one you listed a bit more. I’ve got a 2500 hood and have thought about making the vents functional as well.
Good price for the hood. Wondering where the weak points might be ie: cracking under normal opening & closing etc.
2018 2wd
Both those hoods are nice, one thing about Amerihood is that you will need to secure them with the hood pins and also switch out the support struts and use a hood prop rod to help reduce the risk of cracking them ... they are made of fiberglass which can crack pretty easy especially on hoods.
Buddy of mine returned 3 Amerihood hoods and decided to go with another company from the east coast.
thestuntboy
CT
1999 2500/2001 2500/2018 3500
8.0/5.9 gas/6.4
Going on 3 years now Amerihood. There are fine cracks in front of the Ram decal from being slammed by morons at a Putnam CT dealership. (One of the many reasons I switched) I still like the look and get compliments all the time. I will eventually reglaze it and have it painted.1665551677089.png
thestuntboy
CT
8.0/5.9 gas/6.4
MartyZ
Lake Orion, MI
2500 5.7l Hemi
I bought the truck with them on it so im not sure when they were originally installed. They were dried out but had decent tread left.
I put 30k on them, and yeah, definitely used up more than i should have. haha
I believe you 100%. They wear much faster with IFS than a solid axle, and because of them being cheap, they are manufactured cheap. When its manufactured cheap, your chances of having a defective tire are higher. (Not being a circle, resembling more of an oval)
I rolled all of mine on the concrete at work to see if any wobbled or were off round visually. They all rolled true, but they are also heavy as ****.
Mounting and balancing went very well. Balancer called out for 10oz. weight on the worst tire. Techs said that bags would be a safer bet for balancing them. I trusted their knowledge and went with them. Hit 70 -80MPH on the way home with zero vibrations or wobble. I did take a dirt road for a minute to shake up the bags before hand so I knew they had opened up.
It feels great and honestly these tires seem quieter than the Toyo's were.
Time will tell how wear and traction are, but based off my buddys experiences (2500 diesel, tuned) he loves them and gets great wear and traction.
I hope my deal remains a deal and not a waste of time and money.
Here are some pics, don't mind the filth:
