Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
I bought the truck with them on it so im not sure when they were originally installed. They were dried out but had decent tread left.
I put 30k on them, and yeah, definitely used up more than i should have. haha
I believe you 100%. They wear much faster with IFS than a solid axle, and because of them being cheap, they are manufactured cheap. When its manufactured cheap, your chances of having a defective tire are higher. (Not being a circle, resembling more of an oval)
I rolled all of mine on the concrete at work to see if any wobbled or were off round visually. They all rolled true, but they are also heavy as ****.
Mounting and balancing went very well. Balancer called out for 10oz. weight on the worst tire. Techs said that bags would be a safer bet for balancing them. I trusted their knowledge and went with them. Hit 70 -80MPH on the way home with zero vibrations or wobble. I did take a dirt road for a minute to shake up the bags before hand so I knew they had opened up.
It feels great and honestly these tires seem quieter than the Toyo's were.
Time will tell how wear and traction are, but based off my buddys experiences (2500 diesel, tuned) he loves them and gets great wear and traction.
I hope my deal remains a deal and not a waste of time and money.
Here are some pics, don't mind the filth:
Oh yeah they are definitely heavy tires lol ... 10 oz. is a lot of weight even with the bags, they should of rotated that tire on the wheel 180° to bring the asking weight down ...hopefully they have improved those tires and you match your friends durability with them ...
jib88fer
Hiding in the Hills, TN
Bit the bullet and added the .50cal antenna. Never listen to the radio, but reception is pretty good. I've read the older posts about the studs not fitting, but that was an easy fix. As the case has a 6mm threads, I just tapped them out to the Ram 1/4"-20 and Loctited in a 1-1/4" stud. Had to Loctite the bullet tip as well. Where I live we have vines and brush hanging out in the roadway and my whip antenna was always getting thrashed.
2018 2wd
I've wanted one since I got my truck, but the "Boss" listens to the radio a lot when we go out lol ..she would kill me if her stations did get good reception ...
Socalramfan
Huntington Beach
2011 Big Horn
They look good installed, though I’ve decided to keep the long antenna as it’s a good clearance marker approaching anything low. If it hits the antenna….. the cab is pretty close too
2018 2wd
Too bad that one doesn't expand if needed for that extra reception.
They actually have 5" to 12" telescoping bullet antennas
hunterdan
SE PA
2019 classic
Ok, that's pretty cool....
kad
Hudson Valley, NY
5.7L HEMI
Hauled a couple of trailer/bed loads of furniture from a deceased relative's apartment to the local Habitat for Humanity donation center. As usual, had to keep checking the mirrors to make sure the trailer was there, 'cause you can't tell from how she handles! :)
-K
Adamcr68
Lorton VA
Hemifever 5.7
So I searched the forum for a thread like this and didn't find anything. I figured it would be fun to have a thread that everyone can watch what everyone is doing each week.
This week I put on Steelcraft nerf bars, and right now I'm getting the permaplating put on the truck. This way it gets a real good bath.
Had a fairly light day at work, so I did a wash & wax. She cleans up good for being 8 years old, just can’t get too close for the pictures!
Socalramfan
Huntington Beach
2011 Big Horn
Started a Thread over in the Interior area to continue with the Dash Swap…..
Cleaning of the main frame and applying Protectants to the various parts. Also began minor disassembling of the current dash to make the full swap over easier.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Fixed the Y Pipe on the Pentastar on my 2015 ! 2nd time since 2016 !
First time under warranty !
the bolt at the mounting flange rusted in 1/2 ! Joys of living in the rust belt !
No more warranty so had my mechanic drill out all 4 studs and replace the bolts, So now if happen again replace the nut and bolt !
Way cheaper the 250$ fo a new Y pipe lol
bcbouy
pitt meadows/100 mile house
2021 power wagon
hemi
put my oem duracraps on a set of ion rims,had them studded,and now i'm waiting for snow to swap them with the 35 grapplers.i think i'm going to sell the 20" grabbers. i haven't had a use for them since i got the Powerwagon and sold my truck camper.we have snow on the way in the next couple weeks so a final wax and detail is in order before it's too cold to wash it. once it freezes here it stays that way for months.once they start sanding it is pointless to try and keep it clean.plus washing it turns it into a block of ice.
ChloeBrooks
