wrench78
Air Force Law Enforcement
SE PA
2022 2500 Laramie
6.4L
How do you like your GeoPro? I've been eyeballing them, seem like nice units.
It's ok. It's a little small for us. Bought it cause at the time I had a Jeep Wrangler and it was the max I can tow with the Jeep. It's great for 1 person. Ok for 2. The downfall is the black and gray tanks. At only 12gal each, they fill up really quick. Love how it's made with Azdec panels rather than traditional wood. Less chance of rot.
BenchTest
Midwest
Thanks for the report. What does one of those weigh dry (if you know off the top of your head...I can research otherwise)? Feel like their build quality is good?
wrench78
SE PA
2022 2500 Laramie
6.4L
I have the Geo Pro 15TB. Dry weight on it is around 2720. I think the main body of the trailer build is great. Intierror is ok. Some of the cabinet doors aren't level. 12V fridge is awesome. Freezer gets to around 2 degs. Frig stays around 41 deg when loaded.
BenchTest
Midwest
I'm installing a Fumoto Drain Valve. Going to have a friend come over and help me lift it into place, while I tighten it to 300ft/lbs with my 3/4" impact. I want to make sure it doesn't leak. I also opted for the carbon fiber lined, stainless steel core washer to help seal it. I will be running in some hot temps coming up, so I'm going with 75W90 to the top of the fill port. <laughter implied>
WY-Dave
Air Force
Cheyenne, WY
6.7 CTD
Gotcha. Tbh, I had to look this up. Haven't experienced this one yet...sounds like I'm not missing out. Saw some invisible glass - glass stripper on Amazon. No idea if that works. Also found people talking about using various products/chemicals (some you already mentioned here) and razor blades to get it off of the glass...please share when you get yours to come off. Wish I had a magic bullet to help.
Crap is still there, did the stove cleaner and it did a so so job. I even tried gas afterwards and the _)*(^&) is still there. Next is a drill buffing pad and some rubbing compound
RangerWeaver
York, Pennsylvania
V8 4.7L
Went to leave the house this morning for an appointment and found that my Ram wouldn't start. After looking into the error message, I was receiving I picked up a new IOD fuse and battery. Once I had her back together she started right up.
LumberJakl
Calgary, AB
6.7L 4X4
When I snooping around my AlfaOBD, and came across a 'Off-Road Page' and enabled it. Now I have a new app installed on my UAQ 8.4 in my 2016 Laramie. The only thig that doesn't work is the Pitch & Roll , but the Steering Angle / Coordinates / Guages all work!
Body Computer > Car Configuration Change > VehConfig 2 :Off-road Capable
PA Ram
Navy Badge
Quakertown, PA
I never got mine to work
aszumilo
Navy Badge
Las Vegas
Ordered some new coil springs, got them in yesterday. Put them on the new struts, along with new Upper spring seats. Moog coils, KYB Spring Seats, Bilstein 4600 struts. Going on next weekend, hopefully.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
JW2 Innovations
Supporting Vendor
Sparta, TN
2016 Ram 2500
I bought a lower storage try on eBay for $20...
And added a wireless charger powered by my Power Magic Pro I use for my dashcam...
It charges with all radios on my phone active and connected to Android Auto so mission accomplished.
Very nice!! I looked at several similar to that one when I was doing wireless charge setup in my 2500. I've got similar in my wifes DD, a Toyota Highlander. Works good when she puts the phone in it - something I don't think is happening much in that one. :)
Geawiel
Spokane Wa
I replaced the entire suspension front and back and installed the Billstein 2/4 kit. I had to cut the lower control arm off and the CV axles were seized into the knuckle on both sides. It took me 3 weeks total to do it. I've got severe nerve damage though so I had to have some rest days in there. My trans cooler line was leaking and needed replaced as well. Was a pretty simple job. The only hard part was getting the new one in. I put on long tube headers last year and it was a ***** to get the new line past them.
tnctx02
2017 RAM SLT
3.6L Pentastar V6
Will check this out for my 4x4!
Thanks for the post!
tnctx02
2017 RAM SLT
3.6L Pentastar V6
Was a few weeks ago, but my 2013 Tradesman got a big face lift on the interior.
From this stripped to new cloth seats and center console with new black carpet
dterrel
