What is this?
RedRam2019
Does any one know what this is? I heard a rattling noise and this was found on top of the transmission...20180930_015140.jpg
SYKRAMMAN
Banned
Jersey shore
06 Mega
Looks like something that should be on the truck! Bracket maybe, idk but you should bring it back.
14 Lonestar
It looks exactly like some sort of jig/assembly aid of some sort with serial number.
R
RedRam2019
After taking the truck to the dealership I was advised that it was a tool used at the manufacturing plant that was left on the truck.
McBroom
Denison Tx
Hemi 6.4L
Did they say what it’s used for?
Blue Streak Pearl off-road
R
RedRam2019
I left it at the dealership. It is used somehow in the install of the transmission.
basegroup
I bet the guy that left it on there, went home “sick” that day he realized it was gone.
Then he can blame it on someone else.
I’m sure that’s not cheap or that they have those just sitting around as spares.
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
I'm sure it's great to know that it isn't a problem with the truck....howevuh (spoken like Andrew Dice Clay).....You should at least be compensated for having to take time out of your day (twice - drop off and pick up) and the fuel necessary to drive into their facility due to a mistake on FCA's part. I would write a letter to FCA and tell them you lost a day (or two's) wages because of this and that should, at the very least, be worth a free oil change, tire rotation and truck wash...
Dr. Jim
2019 Laramie CC 4x4
So what about all the Rams that came after yours on the assembly line. If they didn't have the tool, how were all the transmissions installed properly? Or were they....????
Siff
New Hampshire
They just shut down the plant after the only tool they had went missing./sarcasm
This appears to be, at most, a $50 tool; they probably break fairly often, and there are likely dozens of spares sitting around. They probably didn't even notice that this one was missing, which would explain how it made it all the way to the end buyer.
RaptorHD
South Carolina
2019 2500HD
The tool helps to align the Gonklin valve to the overdrive Fresnel sprocket, which couples the front antifreeze aperture to the rear drive assembly..
KentG
SE Michigan
2020 DT Big Horn
HEMI 5.7 V8
something like this right:
The original machine had a base plate of prefabulated amulite, surmounted by a malleable logarithmic casing in such a way that the two main spurving bearings were in a direct line with the panametric fan. The latter consisted simply of six hydrocoptic marzlevanes, so fitted to the ambifacient lunar waneshaft that side fumbling was effectively prevented. The main winding was of the normal lotus-o-deltoid type placed in panendermic semi-boloid slots in the stator, every seventh conductor being connected by a nonreversible tremmie pipe to the differential girdlespring on the "up" end of the grammeters.
wgreggking
rural Arizona
2017 4x4 offroad
And to think I thought it was a muffler bearing, wow its a tuboencabulator!
Bramo
