What rear end do I have?
FullForceRam
Brentwood, Ca
5.7 Hemi 2WD Quad Cab
Hi all,
I'm trying to research what rear end gear ratio I have on my truck, but using the VIN number on a few sites and I'm not able to locate this information. Is there a specific way to find this out without removing the rear differential cover?
2014 Express quad cab 2WD w/ 5.7
Thanks.
FullForceRam
FullForceRam
Brentwood, Ca
Nevermind.... found this website and has everything on the build of my truck. If anyone else needs this info, copy/paste the following link:
CharlesinGA
50 miles south of Atlanta, GA
5.9L Cummins 305 hp HO
Two things. First, the ViN decoder requires that you enter alpha characters in UPPER CASE, it will not work if you do not.
Second, look for a sticker inside your glove box door that the factory put there. I think it has the gear ratio on it.
Charles
DeerDuke
Earth
6.7L Turbo Diesel
This link will allow you to input your VIN and pull up your Equipment List:
