what would cause this?
02blkram47
Lebanon, NH
2018 Ram 1500 Limited
So for the past few days I've heard what I think is water or coolant maybe while driving. So basically if I come to a stop and then take off I hear water splashing around or running through pipes . It sounds like its in the passenger side of the dash. Any thoughts?
Also my truck has decided to idle 100 rpm lower all of a sudden. Since I bought it about 7 months ago it would idle at 600 rpm like clockwork. Now its 500 and it seems too low to me. It even stalled once yesterday in traffic.
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
Sloshing sound is probably the heater core if its coming from the passanger side. Is the passenger floor wet at all?
Bigdaddyii
Check an make sure you have enough coolant in the radiator. Does the heater work?
SmokedRam
Zephyrhills, Florida
Check your coolant level...see if its low...if it is, top it off and burp the cooling system to get any air out...then see if you hear the sound anymore.
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
heater core.
probably tps.
ramthis9501
Oklahoma
5.2 V8
Mine will do it every now and then, but my heat works fine
02blkram47
02blkram47
Lebanon, NH
My heat is working fine. My AC on the other hand isn't. Ill check the level of my coolant today and top off if needed. How do you burp the system? I saw the thread on the IAC ill give that shot. Thanks
Bigdaddyii
There is a bleed screw to do it the "right" way. This has never worked for me though.
What I normally do is park the truck with the nose as high as I can get it. Let it cool off and remove the radiator cap. Top off the fluid and run the truck with the cap off until it reaches normal operating temp. All of the air should rise to the highest point, which will be the degas bottle, and escape through the open cap.
SmokedRam
Thats how it's done!!!
rambob
LA/MS
318 5.2l
usually means air in the coolant system.
I agree with check the level of the coolant first.
it may need to be burped if the level is good.
sorry, lots of posts while I was signing in.
yea, what they said. lol
