Whats biggest thing you've towed with your 1500?
Gone-broke
My Jeep on a 16' flat bed trailer.
Sent while driving...
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
34' camper fully loaded at about 12-13k. Plus camping gear in the truck.
Sent from my DROID RAZR using Tapatalk 2
garner
Harker Heights, TX
2008 1500 lonestar quad cab 4x4 with a level and body lift and ranchand front bumper. Pulled it around the parking lot
Sagebrush2500
2013 2500 Big Horn
I once pulled a loaded construction office trailer with my '97 1500 5.2 - far heavier than my tow capacity and couldn't move it until I pulled the level to 4wd low lock and that big gear did the job.
My truck was pretty unhappy with me.
Gardenfan
Chetwynd, BC
There are many many Vehicles that you can leave the driveline in and haul around with the transfer case in neutral.
hell 4th gen ram 4x4's you can provided all 4 wheels are on the ground, like behind an RV. Most Jeeps can be hauled safely with no damage. Any GMC 4x4 that you can get the transfercase into neutral you can tow it with any combo of wheels off and on the ground you want across the country safely.
MADDOG
Living in a Firepit
Nothing big at all. Little trailers, like the one below, is all I've towed with this truck:
Didn't even need to fold out the mirrors with this one!!! LOL
hounddog
Charlevoix, MI
2017 laramie 2500 credit cab 4x4 cummins
I towed our new JD9560R out of the shop and about 500 feet to where we loaded it up today. Blown transmission so even though it is only about four months old, it is headed back to the dealer.
41,500 or so pounds.
Not this one but one exactly like it. (this came from the JD brochure)
Race1Mopar
2x4 drop with helper bags in the back. She gets her share of towing duty, lol.
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
crappy pic but my jeep was the heaviest ive hauled yet, and ill never mess with a car dolly again if i dont have too btw
Yer not supposed to tow a cherokee backwards like that. The manual says it could cause the back glass to break, since it isn't designed for the air pressure it sees.
At least the manual on my two say that.
sullivan
Houston, Texas
Whats the best size ball mount drop, and ball size to buy. or should I ask what is the most common size used.
Cthulhu
Calgary, AB
Cummins 5.9
It depends on the height of your trailer draw bar, and the coupler size ... I had my 2 1/2" drop and a 1 7/8" ball on my 1/2 ton that worked often enough I still cary it in my 3500.
Sent from my Tapatalkin' BB 9800
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Most trailers are 2" these days unless they are heavy then you will be at 2 5/16"
I use 4" drop for boat and straight tri ball for trailers that weigh a lot like the one below. This was before airbags though so I can use 4" drop for all now.
The larger the shank the higher capacity it can handle.
Hauled this nice trailer to move my parents.
$miley
neverdun
PARKVILLE, MARYLAND
HEMI 5.78
I towed my 40 ford to Nebraska and my new 57 chevy back. It went great. I love this truck for towing.
BLKDODGE04
Wataga, Illinois
4.7 Magnum
8000 pound skidsteer is the heaviest ive hauled. was a bobcat 853H i believe. didnt tow it very good, not with the 4.7 haha. need to get my 4.56 gears...
TMFMK
