The 180* thermostat will only help on vehicles that are routinely operated at elevated temperatures. Basically, if you do a 2 mile drive to work in 40* weather, you will be doing more damage than good. The reason for that (as stated above) is that the truck will run richer at 180* than 210*. This is because the engine map has a separate table that adds less fuel as the engine warms up. This is because the fuel evaporates slower at lower temps than higher temps so the injectors must add more fuel to the intake to let it evaporate to the combustible gas that you want.
Also, an engine that never gets oil above 212* will never boil the water out of the oil. This can cause premature wear. Unless you are building a race car, tow a lot, or live in a very warm climate, let the engineers at Chrysler do the work for you and keep the stock thermostat.
Edit: The truck will not actually run "rich", it just uses more fuel to maintain the proper AFR.
