Wheel alignment data
Auckland, New Zealand
Hi:
Have had uneven wear on the front tyres. Outsides have worn more than inside with only 10k on clock.
Can someone share the wheel alignment data please.
crazy jerry
WY
first off its not uncommon to have a bit more wear on the front outer. the knucles may have alittle positive camber which isnt adjustable. and if you drive like a mad man around corners it wears it even worse.
second thing is you shouldnt let rotations go past 5k mi. 3-4k will help the tread last a bit longer but most people couldnt be bothered with that.
10k is far to long if you want the tread to last
olyelr
Kewadin MI
Yep, i try to rotate by 5000 miles or less, with having them balanced around every other rotation. I will wait on the balance if they arnt shaking bad just to save a trip to the tire shop. My last set of tires (35” falken at3w’s) lasted over 60k miles before i took them off, still in damn good shape with no major cupping at all.
This is how all 4 look still…
And, for what its worth, i bought the truck new 7 years ago and have never had an alignment done. I did do a little toe adjustment in the driveway years ago.
Power Wagon NZ
T
Here you go....
Also very important you rotate the tires on these trucks often.
Thanks
