wheel help
Gen2Ram
Massachusetts/New Hampshire
5.2l V8 Magnum
So I just finished lifting the front of my 1500 4x4 with 3/4ton Cummins Springs. I want to run a 315/75 R16 tire. I understand that there will be a little rub. Can someone as explain to me the exact back spaceing lug pattern width..... everything I need to know to make the 315's fit with as little rub as possible.
jsmith
The Topgun 3" lift/level claims you can run 35s with a 4.5" backspace rim so I'd think that would be pretty close to optimum for least amount of rubbing.
