Wheel noise
crackerjack007
Tucson, AZ
6.7 Diesel
Any experts out there who can diagnose this sound? 2010 Dodge Ram 1500 TRX4 with 85,000 miles.
rzr6-4
nebraska
'09 2500
1) If you jack up the wheel, getting it off the ground, can you make the wheel move up or down, left or right?
2) Does it still feel normal when driving? Strange sounds or pulling you to one side or the other?
3) Have you used your 4wd lately?
C
crackerjack007
Tucson, AZ
6.7 Diesel
1. Yea to all.
2 doesn’t feel right. Doesn’t pull to either side. Then there is the sound from the video.
3 yes.
Jeepwalker
WI
2012 Reg Cab, 4x4
Because TRX's use such large tires/wheels, wheel bearings would be the first thing a guy ought to check out. A guy could jack that wheel up off the ground. Put his hands at the 12:00 and 6:00 positions, and push/pull in/out at the top/bottom vigorously...with force. If it moves at all... it's the wheel bearing. Then it's a matter of replacing.
Even then, however, a wheel bearing can fail over time ...can be as long as months...or minutes. Usually not minutes. I drove back from Denver to WI on a wheel bearing that was failing. When I got back the tire wobbled in/out a LOT raised in the air! LOL.
Having said that, if there's the possibility of putting all 4 wheels up on jackstands, a guy could take a long wooden stick, say, a broom handle, and place it on the hub on the inside of the wheel (as the wheel is turning) and the other end to his ear. If the bearing is failing a guy will generally hear (transmitted through the stick) loud whirring sounds...if not outright grinding noises. That's an old-timer's way to hear inside the bearing. It works. Obviously yer mechanic or whoever should observe all safety precautions.
Check both sides. Also look for any oil leaks or 'wetness' on the F. Pass side front axle.
C
crackerjack007
Tucson, AZ
6.7 Diesel
Looks like you were right. Front passenger wheel bearing appears to be shot. Left seems fine though.
Thank you!
Jeepwalker
WI
2012 Reg Cab, 4x4
Glad you found the issue. Are you going to change it yourself? Or take it to a shop? Just curious.
osprey ram
09 1500 4x4
4.7 lit.
I have a 09 1500 4.going to replace the cv axles soon. Truck has112,000 on it. Would it be a good idea to have wheel bearings in stock to do at same time ?
