wheel spacers
Sir John
Buffalo, NY
2016 1500 Rebel "Mopar 16" Special Edition
I'm a total noob on spacers. I'm assuming that they push your rims out, away from the truck? Are there any downside/side effects to having them on? I have a 2016 rebel with the Mopar fender flares and when I look at it, I keep think the rim/tires should be farther out. If I did that, I would use "wheel spacers"?...1"?
quietpeen
2021 TRX
Hellcat
just looked on the website, rockstars are availabe as 20x8.5 and would have +10 mm offset
quietpeen
2021 TRX
Hellcat
yes that is exactly what they do....with your truck i would be worried about possible rubbing with the active air suspension if you push them out too far
stevens
stevens
2015 Dodge Ram sport 4x4 crew
active air suspension ?
>.< uhh lol..... ill shoot some pics tomorow for you guys. show you what i got running.
quietpeen
2021 TRX
Hellcat
Sorry I was replying to another poster. But to help you we need to know the exact specs of your wheels. You say they are 20x9 rockstars but ther website shows 20x8.5 or 20x10.
stevens
stevens
okay i will defff look tomorow where abouts can i find that info? will it be on the front side of the rim? inside????
joeygster
Ancaster, Ontario
A question regarding the spacers & Loctite.
I've got the Bora 1.5" spacers on my winter set of wheels/tire. They were installed by a very reputable shop that routinely deals with spacers so I assume they used Loctite on the spacers.
Once spring arrives, I'll be doing my own switchover to my summer wheels. Am I going to have any issues removing the spacers using a breaker bar with the Loctite on them?
Then when next winter arrives, I'll re-install using the Loctite......is there a specific Loctite I should be buying for this type of application?
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
You can measure the width of the wheel simply with a measuring tape. The offset should be stamped on one of the inside spokes.
Don't install them with Loctite. Between that and the corrosion that will happen in there they become next to impossible to remove. I used Loctite when I first put mine on and I thought for sure I was going to snap a stud trying to get them off. The last two years I've installed everything with Never Seize to fight the corrosion problem. I haven't had a single nut come loose. So essentially I recommend doing the exact opposite of what you're thinking.
joeygster
Ancaster, Ontario
OK thanks Brandon.....
I saw several mentions of using Loctite in this thread & thought I better inquire because I hadn't heard of it being used until I read it in the thread.
BlownGP
Houston/Baton Rouge
Oh hell no. You dont want to use loctite on wheel adapters.
I've got my 1 1/2" from MyWheelAdapters.com and have been fine going on 4 years.
I check the lugs every now and then, but they are never lose. I do TQ them to 130 ftlb.
