Wheels and offset
cincygoat
I am sure this has been talked about a thousand times I am looking to get wheels I want to stick with a 17in wheel and put 33 12.5s on them number 1. will i have any clearance issues after a leveling kit also I have been trying to wrap my head around these offsets lol I am so utterly confused I have seen trucks with a -12mm that look good which is what I want for mine but I have also seen some with 20mm offset that look the same can someone please help
237-238 Gauntlet - Ultra Wheel
these are the wheels that I have been thinking about getting once again please help me understand
BlownGP
Houston/Baton Rouge
The lower the offset the farther the wheel will be pushed out..
The higher the offset the farther the wheel will be pushed in.
This is all in relations to the wheel hub.
Now width of a rim plays a part in this too.
But the ones you want a 9" which is the same width as most of our stock rims
This is a good calculator for seeing how far the wheel will be moved out.
Stock offset is +19
Wheel Offset Calculator | 1010Tires.com Discount Online Tire and Wheel Store
