Where have you installed switches???
Blkngld
Central Jersey
I'm hoping this setup will work for my front camera and lightbar, 2 latching led 16mm buttons under the shift dial....
I used those same switches in the front of the center console... I used those on the end and three smaller ones in the middle. Hard to see under the picture, they are right under the CB. Those switches worked great until I got my switch pros.
customcarz973
There is a switch panel coming out that replaces your homelink on the overhead console with 3 push on / push off out puts to trigger external relays. Very exciting lol still waiting on the eta.
MarshRam
2014 SLT 4x4, 2012 ST
Huge pita and requires a little modification to the terminal to get it to fit in the socket, almost better off just cutting off the back half of the lighter socket. Just temporary nonsense until I get all my lights hooked up and put the 6 switch AEV pod in!
MidwestJ
Illinois
I have a 2011 with centre shifter here's a pic of where I put mine there's only enough room there for about 3 switches
Just moved my switch yesterday to this location based on your post.
It was at my left knee under the wheel but I didn’t like it there. I couldn’t see it for quick toggle. Had to hunt for it.
I wanted it in this spot (up high like yours) originally but was intimidated by the plastic and routing etc.
After reading your write up-it was a breeze and I now have mine there for quick, easy, visible access.
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
How are the switches wired? Are the battery or auxiliary sources?
Battery thru fuse/relay block
dakota18
