Dex can be a real issue in older rigs. Turns to almost like clay especially if there is a leak. Funny part about coolant is new ones are rated for 5yr/100,000 or even 150,000 but people were doing that with the old original green too. Seems like coolant is neglected by most people. They change it at best when the water pump goes.Well, they could have done like GM, after all it was GM that is at fault for everything. if not for dex with that stuff in it there would have not been any damage or mis information.
Color of OEM coolant can change color to look pink/purple depending upon temp of the coolant. Now ambient temp color can look different alsoMy 2019 have OAT ,pink color.
You are consistent. You have been adding value for a long time!I don't know much about the universal coolants, I do know for some guys who peeled this onion, peak global life is particularly popular. Some of those guys like Syn aren't active anymore, but in this particular area some of the work on BITOG could shed light on it. Come here for oil advice, go to the oil site for coolant advice, lol.
Have the truck 2 years now and so farr still pink in the reservoir tank.Color of OEM coolant can change color to look pink/purple depending upon temp of the coolant. Now ambient temp color can look different also
So the "all vehicle universal" coolant by prestore has the same thing as dex cool, I just looked it up in safety data sheet. 2-Ethyl Hexanoic Acid, is in prestone all vehicle, here is sds.See guarantee below!
That is the Platinum. Did you check the normal universal as well?So the "all vehicle universal" coolant by prestore has the same thing as dex cool, I just looked it up in safety data sheet. 2-Ethyl Hexanoic Acid, is in prestone all vehicle, here is sds.
Now I see why people like peak global life but leave the prestore alone. Learn something new every single day.
will do this very minute. That was universal, I will check the other one too.That is the Platinum. Did you check the normal universal as well?
