Which lift kit do I have?
Maverick10
Abbotsford, BC
Hi, new to the forum. Just purchased a 2014 Ram 1500 Sport w/hemi
It has a Pro comp lift, but I'm not sure if it's a 4 or 6". I need to get some new shocks and would just like to know. I believe it's a 4" lift, but the front has adjustable coilovers, I thought were only available for a 6".
Any help would be much appreciated. I know it's a bit rusty under there... but got it for a deal
Maverick10
Maverick10
Abbotsford, BC
Also and may be good to add. Previous owner put a tire a tad smaller than a 32” on it. Not even stock size tires. Plan is to get different rims and 35’s
thkbaron
Minnesota
and they took **** care of their coilovers.
rwhjr
maryland
Wow. That’s a ton of rust for a 6yr old vehicle...
At first I thought maybe you got a bad/faulty coating on all the ProComp pieces but even the OEM components are toast.
Measure from your center of each wheel hub up to the fender edges and report back with those #s of you can.
Maverick10
Maverick10
Abbotsford, BC
Yeah it's been up north quite a bit I think. Body and interior in great shape. 8 speed tranny shifts awesome. Rusty ugly underneath. I'll get those measurements later, but I did measure where the front control arms and the rear links would have bolted up stock, and it's 4" front and back.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
The 4" pro comp kit did not come with coilovers only top spacers for your existing OEM setup. You obviously have a aftermarket coilover there. You can replace them with pretty much anything your wallet can afford at this point but your lift is 6".
Maverick10
Maverick10
Abbotsford, BC
How we're you able to see that it is a 6" lift?
Maverick10
Maverick10
Abbotsford, BC
Just need to confirm, so I can buy the right length shocks for rear and coilover struts for front.
Maverick10
Maverick10
Abbotsford, BC
Mine has 35's and a 4.5"
so yours is 6"
You figure that by just the wheel well gap? Sorry, don't mean to sound like I doubt you. Just really want to get it right. This stuff isn't cheap :(
But if that's the case, keep in mind the tires are on here are just under 32's on 20's. 275/55r20
Maverick10
Maverick10
Abbotsford, BC
I saw, my OCD kicked in!
Yeah, I'm going to clean it up under there. The body underneath is mint. And frame isn't bad. Just the components. Replace some of it, undercoat or paint some of it. I'll clean it up
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
get that measurement that was suggested, hub and lower fender, then we can narrow down.
Graygoose
Oklahoma
Convert, for now.
small
Oh I hear ya, thats trucks of the north sir, no ill intentions at all.
thkbaron
Minnesota
actually it's not terrible underneath for 6 years old if it's been in salt.
Maverick10
Maverick10
Abbotsford, BC
So I measured center of hub (center cap) to the fender. I have about 27.25" up front. 29.5" rear
JB1
Houston, Texas
You need to measure the procomp rear spacer, the 6” kit uses a 4.5” rear spacer while the 4” lift is about 3.25”. The MX 2.75 coilovers were an option on the 6” stage 2 kit.
