Kotta390
I understand what your saying, but we both know 1 7/8ths is over kill. Doesn't matter if it's a 5/6 speed, 8 speed, or 20 speed, if you every see under 4000 rpms at wot, you will be affected negatively by the larger primarys at our power level
In theory you are correct. I don't even run 1 7/8 on my Shelby truck, which it actually needs I might add. These new VVT Hemis also have an active runner intake manifold for best low end torque and top end power. I have talked to Ryan about this and he said with the headers he can tweak the bottom end if need be to recuperate any low end loss from the bigger primary. My truck already has a substantial increase in low end now just from his tune so even worse case scenario the truck will lose a little low end it has now and still be much better than stock. But you are correct and I agree 100% that these trucks don't need a 1 7/8 primary I am not willing to fork over the cash for Stainless or ARH. Now if you drop me $700 out of your pocket to help buy longtubes I will gladly get some ARHs lol.
6000 rpms now. When I ran last at Ennis I was shifting at 5700 rpms because of a TB closure issue but that's figured out now. My shift recovery on 33" tires is above 4500 which is above max torque if I'm not mistaken.What are you shifting out at mike?!?! 6000-6200?
You buy me some 1 3/4 longtubes and ill prove it. I know youre not going to buy both and test the theory. No one on here will prove which one is better.
From what I can tell between the 1 3/4 and 1 7/8 guys that run at the track, it is too close to tell which one is better and from the 8 spd standpoint I haven't heard of people losing low end torque like some people do when they just chop off the stock muffler. Just an observation I have seen so far.
