Whipple supercharged 6.4 based 426 build
Tk91
California
6.4 srt swapped
I have a 160 degree thermostats along with a derale oil cooler . Any suggestions on getting a better oil cooler without sacrificing pressure drop ?
And would love feedback on these aftermarket radiators
Just answered you on your message,lol.In your case with what you're doing with the truck,a Hellcat or Melling high volumne oil pump might work in your favour,and allow you to run a bigger oil cooler and not have pressure drop be an issue. It used to be common to upgrade to a bigger oil pan to,but i'm not sure what all is available for a larger capacity oilpan for the trucks,but you could easily modify the stock pan to hold more oil,and fab in some added length to the pick-up tube. I used to use 2 oilpans to make one,on some of my older oddball hi-po builds.
Lowrider357
