Whos got the most miles on their 5.7?
Ramrodd
South Carolina
153k on my 09 and had a lifter lock up at 111k. No issues since. (“Knocking on wood”)
TRXHemi
Sugar Land, TX
2014 just rolled 187K.
Only major issue was Cylinder 1 had a cracked valve spring. It happened right after an accident, however they could not determine if the accident caused it or not. I was rear-ended.
Beside that though, flawless so far.
Big Daddy
My 09 just crossed 290,000
Repaired
- Rear end blew due to faulty pinion nut
- Exhaust bolts
- Upper control arm and tie rods RT side
- Rt side wheel hub
- Cam broke at 160K
- Rt side coil packs 140K
- Water Pump/fan clutch 140K
- Trans shift solenoid 80K
- 3 sets of shocks
- alternator
- power steering pump
- 6 sets of tires
- 4 sets of brake pads
- 3 belts
- 10 sets of spark plugs
- Heater core
- AC Evap
- 2 heater solenoids
- 2 sets of lug nuts
- 3 coolant flushes
- Many, many,many oil changes
Trailmaker
Locked and Loaded
Conroe Texas
2021 PW
23k on my 19PW.
109k 2011
Edit. I see this is for the 5.7
My bad.
Marshall
Sk, Canada
2014 sport
2015 just turned 100,000 miles.
I really have enjoyed this vehicle and the adventures it has taken me to. The only way it will be replaced is if its unfortunately wrecked. :( But then I'll just find one of those hellcat trucks or Durango's :D:D
That is what happened to my 09 Laramie at just under 100KM
my 14 sport , red is about 70KM
The wife's 2008 Honda CRV is also just under 70km.
ErnieD
Colorado
2019 Ram Big horn 5.7L; 18300 miles. Drove it off the lot with 10 miles. 5000 of those towing my ATV and pop up trailer. Feels good to know I’ve done every oil change myself
mreservices
WV
2016 Ram Laramie 4WD
2016 Laramie with 34k on it. Bought it used in December with 21k.
CYSTemrebel
R R 1 Harrowsmith
hemi 5.7 liter
My 2008 2500 5.7 six speed standard has 202,823 miles Running 10-30 and next change to 10-40. Oil changes around 15000 miles running synthetic and oil filters every 7500 miles. Replaced front end, new alternator, starter, battery, and on second set of snow tires and second set of summer tires. Nothing major for this work and play truck. Most miles on it are highway miles from the USA hauling a slide in camper. Latest discovery is an oil pan I must replace because of rust and a steering shaft section with a universal on one end. Still all kinds of power but pinch joint rear fender problem requiring inserts.
