window auto one touch stopped
alex6666
kamloops b.c.
2017 1500 slt
2017 tradesman crew. Orinially when i got the truck the front windows would auto up or down one touch but for some reason this has now stopped and requires constant up or down. Any ideas?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
This happens to me occasionally too. You need to roll the window all the way down holding the down button the whole time. Then roll the window all the way up holding up the entire time but when it reaches the fully closed position continue holding the up button for 5-10 seconds.
When you release it auto up/down should be working again. Repeat for the opposite window if needed..
A
alex6666
kamloops b.c.
2017 1500 slt
thanks......it worked :) this truck does some weird sh.....last time my oil change reminder light came on it disconnected the cruise control.....got it fixed but weird.
Dean2
Near Edmonton
That fix is in the owners manual, as is the fix for the power seats not going back for easy exit. What trips the window auto is if it feels resistance closing it will stop and it de-selects the auto close/open till it is reset.
moparchas
High Ridge MO.
tried what you said and it worked thanks for the information
