Window/speaker not working
korby05
Delta, PA
5.9 Magnum
So over the weekend my fiancée and I went to the drive in. I went to put the back drivers side window down and nothing happened at all. Neither the drivers switch or the one on the door will operate the window.
I don't think the motor is bad in it but very well could be. The speaker isn't working either. The locks operate on the door.
Any suggestions would be great.
RonJon '06
Southern Minnesota
Pull back the rubber boot that surrounds the wiring going from the truck body to the door. My guess is that you've got some cracked/broken wires inside. I had the same thing happen on my '06.
K
korby05
Delta, PA
5.9 Magnum
I was thinking that and just wanted to make sure. Seems pretty straight forward in doing it. Thanks
Sent from my SM-G920V using Tapatalk
