windows
lexican
Hi all. Just bought an 04 and all windows switches but driver side don't work. the driver side will lower and raise front and back windows but that's the only switch that will work. already tried switching out the switches but still wont work. any help would be appreciated,
clay
Peguis, MB
Hi, I'm new on here and I have an 05 Laramie with the same issue.
dmacell1
levittown PA
hemi 5.7 supercharged at 10psi
I had this issue on my dakota qc and it ended up being the master control switch on the drivers side door. Once i replaced it they all worked. Something to do with the lockout mechanism on it.
brantner22
4.7 V8
Sounds like the wiring in the boot between the doors. Generation 3's are horrible for the wires in the door breaking. Look between door and body of the truck and you'll see the rubber boot. If this is it, it's a simple fix. Solder, shrink wrap and put back together.
