Windshield Wiper Fluid Notice
SupermanWV
Rain-X messed mine up. I put blue cheap stuff in after rain-x was empty. The light went off and has never came back on. I have a 2013.
Sharp Charge
Brunswick Oh.
You know, I've been waiting to see something pop up here about this. I refilled my tank last month with the orange rain-x fluid and my light has been on since. Sucks because I've got 1 more gal of it sitting in the garage. lol
WulfGang
PA
Mine went off. Hasn't came back on. Yet.
vtron
Mine does the same thing when I use Rain-Ex. Has anyone found a way to fix the sensor? I'd rather completely disable it (short it) than switch to the crappy blue washer fluid.
JJP71584
Pgh, PA
I called the dealer and told them what happened, first question from them was if i used Rain X, I said yes, they told me that it coats the sensor. I'm going to try and clean it or I'm going to replace it, it's been on for a few months
Knotts89
Montvale, Va
Pulled my sensor out and cleaned it the other week my light hasn't come on since. I refilled with the blue stuff.
sds
Where on the washer tank is the sensor? I have been having fits with my warning light but haven't figured out the cause yet. I just purchased the vehicle ('09 1500 TRX) and started having problems last week. I pulled the washer fluid motor and it works fine. Pulled the little white filter and it had some kind of slime on it. I cleaned it off and go things working but a day later it happened again. I pulled the filter and it had the slime again. I cleaned it and flushed the tank and it now pumps fine but the that light is making me crazy! I'll pull the sensor if I need to or bypass it somehow or ??? But I need that light to go off.
Thanks,
SDS
preachp
The Con State (CT)
Hi All,
I would imagine that the same film that causes the water to bead off the windshield causes a high resistance condition on the sensor plates (tips). This turns on the washer fluid light. Apparently when the blue stuff is put back in it cleans the sensors and the system functions normally again.
JMHO
preachp
BigDaddyRam
San Antonio, Tx
i use about two cups of fabuloso and fill with water. it smells nice and cleans the windshield great! i've never had an issue with the sensors. road grime and oil come off like nothing.
Reticle918
