Wiring door locks need help!!!
jjaj81
Houston Texas
3.7L
Any one know where the wiring runs to for power window and door locks?
I have a manuel everything in my ST and I bought everything I need to add power but have no idea how do run wiring.
WhiteExpress
Midland, TX
It is highly likely the wiring in the dash is there, but you'll likely need new door connectors and the harnesses that go inside the door at a minimum.
In addition you'll need the power window relays (also, these are likely pre-wired).
I don't know what else you might need to make it all work, my guess would be find a wrecked truck and take everything you can find.
HolyRamBatman
Deep in the Heart of Texas
You are going to need a few things.
Regulator and motor for window
Door actuators for the locks
Wiring harness for both probably comes in the same harness.
The wires will run through the rubber boot at the door jam.
You will also need new interior door skins to cover up manual window hole and give you a molded spot for controls.
Under the dash of my 96 I found connectors for the doors to hook up to but I didn't look for anything else.
Bourne2Shoot
NC
If you take your door panels off you may find that it is already wired for the windows, you may just have to connect to the connectors, ( they like to only make one wiring harness to fit trucks with many options, cheaper that way)
