Wiring help for 3rd brake light on truck cap
LSaenz
Laredo, TX
I recently failed my inspection because the 3rd brake light on my truck cap is not connected. Through research, I found out about the wire underneath the truck specifically for this purpose.
After wiring it up, the 3rd brake light still didn’t work. I tested the brake light itself with a separate power source and it works. I used a bulb tester on the wire underneath the truck, and it gets no power when the brake is depressed. How do I solve this problem?
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Wire it into the the 7 pin trailer brake connector behind the bumper
M² Mods.
