Wobble in the rear after 2/4 Belltech?
ezmoney
Maybe Core 4x4 adjustable rear control arms would fix it? I don't know if you've already tried that. Are the rear control arm bushings worn out?
G
Geawiel
Spokane Wa
How much weight do you have in the bed or hung underneath (spare tire)? It all makes a difference. Just curious
Empty bed and just the stock size rim and spare.
I found a little play in the trac bar relocation bracket. I could move it by just a millimeter by hand. Not much but that was by hand so with the full weight I could see that being an issue. I took it to my base auto hobby shop and they welded the plate in place. So far no wobble/wag. I took the long way home from the base and hit the same short interstate stretch as well. Even with the shocks set to 8/18. I also have a local shop checking the pinion angle just in case. I don't foresee that being the issue though.
I go soon to a follow up for that pain clinic thing across state. I'll get a good feel for it after that. Hopefully the bracket was the culprit.
dakota18
