Wont recognize key. Truck won’t start
U&A
2016 3500 SRW
6.4 HEMI
I’m thinking for some reason the truck is not liking the key this morning. Most of the time it does not even acknowledge the key is being put in. Just yesterday were looking at the information on the display in the truck it said I was running at my normal voltage.
What is going on?
I have the battery currently disconnected and I’m going to wait for about 30 minutes and try again. If this is an issue with the truck recognizing the key from what I understand this might solve the problem at least for this morning.
Any ideas? Guess I might not make it to work today.
Kenepo17ram
Brooksville, FL
What is going on?
Does it do same thing with the spare key?
Sent from my GM1915 using Tapatalk
Reactions: U&A
U&A
U&A
2016 3500 SRW
6.4 HEMI
Good idea. Ill check.
FYI, not sure if it matters but this is just a standard key9302ebf8ce3e1872093476ec5b6cc06c.jpg
U&A
U&A
2016 3500 SRW
6.4 HEMI
Did not work.
More frequently now it is saying wrong key when I try either key
Battery was unhooked for about 20 min
U&A
U&A
2016 3500 SRW
6.4 HEMI
U&A
U&A
2016 3500 SRW
6.4 HEMI
Nope.
Didnt work. Same ****
Tried it twice
U&A
U&A
2016 3500 SRW
6.4 HEMI
Currently The battery has been disconnected again I touch the cables together for a good 30 seconds and now it is sitting with them still disconnected until I can find out more information.
This ******* sucks.
No idea what to do besides start calling shops.
But How the **** am I going to get there ...now I got to tow the thing[emoji35][emoji35]
AFMoulton
Nuevo Mexico
Stephs Durango did this and it ended up being a battery in the fob.
You have the regular Ram key right not push start?
2018 2500 6.4 4x4 4.10 Amsoil SS 0w-40, Softopper
Black Rhino Arsenal 18x9 +12mm
Cooper St MAXX LT295/70R18
66RFE/68RFE Thermo Bypass Valve Install
2016 Durango 5.7 AWD 3.07 Redline 5W-30 RP 10-48
1996 Nissan Altima 2.4 Amsoil SS 5W-30
Reactions: U&A
DodgeDude99
Oak Lawn, Illinois
My ‘14 2500 did this a couple of years ago. I could unlock it & remote start, but wouldn’t recognize the key, even the actual key. Had to have it towed to the dealer for a new ignition switch.
U&A
U&A
2016 3500 SRW
6.4 HEMI
Regular key. No fob. For some reason this tradesmen did not come with a key Farb just a regular key that I have to stick in the door to unlock it.
Not sure maybe there’s some kind of chip in this key....?
U&A
U&A
2016 3500 SRW
6.4 HEMI
Currently have The battery disconnected and I have my battery tender on it. I do not have a battery charger. [emoji2957].
Never replace the one i hade a few years ago.
Charging the battery up a little bit only to see if a low-voltage could be causing the key issue. I also have my heated battery blanket plugged in
AFMoulton
Nuevo Mexico
There are chips in keys. For anti theft, dealer can reprogram them. How cold is it there this morning? I’ve seen that cause problems
And just for my ******* you key isn’t this right ? Yours is actual silver key?
U&A
U&A
2016 3500 SRW
6.4 HEMI
Just tried to post a picture again. Look further up in this thread and you can see you have a standard key. Apparently I’ve reached my “cap” on the number of photos I can upload with “Tapatalk free”
U&A
U&A
2016 3500 SRW
6.4 HEMI
And its not cold at all. Its 25 degrees and snowing
Hemi395
Cape Cod MA
Do you have anything you can check battery voltage with? These AGM batteries have a tendency to die all of a sudden....
KC Cryptkeeper
KCMO
2015 Ram1500
Even the old style key key has a chip in it starting 15-years ago roughly.
AFMoulton
Nuevo Mexico
Sent you a text....can’t post pics either
Reactions: U&A
Hemi395
Cape Cod MA
The good news is if it's the ignition module they're only about $85....
ROYSZZ4
