wont run
davy j
here is my problem, Every time I turn the key over the truck runs for about 2 seconds then shuts off. It will crank and run if I disconnect the positive cable for a few minutes then re connect it for one start then I have to do it all over again. What the heck does this mean?
SyrenSkywolf
Hemi 5.7 - Hedman Shorties - K&N CAI
It sounds like isn't recognizing the key. It thinks you are trying to boost the vehicle. If you have a manual, it covers this and what to do.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I agree it sounds like it doesn't like your key. Have you changed keys or do you have another that you have successfully used before?
D
davy j
that's what I was afraid of, Ill try thanks:cheers:
joshhhh
