wont shift properly help
gallis95
maryland
Changed governor pressure sensor and solenoid.. did a tranny flush..
It will shift up if i let go of the gas pedal but it doesnt shift if im on the gas... the truck can downshift perfectly but it just wont up-shift until i let go of the gas pedal
its a 2000 ram 1500 4x4 5.2
any help would be appreciated
kpd12
5.9 Magnum
Transmissions are not my strong suit, I'll be the first to admit, but have you tested or recently replaced your TPS sensor?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
+1 for TV cable. I know mine will run all the way out to the rev limiter if I have it WOT...so I lift to make it shift.
Merc225hp
NA
truck
gas
@DD94 Rev what now lol.
G
gallis95
maryland
update!!! SO i did the band adjustment and it shifts with partial throttle now... but it wouldnt shift at wide open throttle/stomping on the gas pedal... any suggestions? imma try the tv adjustment tomorrow or Saturday
G
gallis95
maryland
if that don't work......shift solenoid, govt pressure solenoid is in your future
I already replaced those two sensors... like 200 miles ago... i tried doing the tv adjustment but theres too much slack in the cable so adjusting it doesnt do much
G
gallis95
maryland
i just checked turns out the throttle valve spring near the trans was disconnected.. SO i reconnected and the truck shifts almost perfect.. at 90 percent throttle itll shift perfectly downshift or upshift its good.. but 100 percent throttle it doesnt shift.. it revvs past redline.. please help me fix this.. let me have a perfectly shifting truckkk.. help a dodge brother out so
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Sounds like your TV cable needs to be loosened just a tad.
G
gallis95
maryland
loosened? should i just keep trying new adjustments until it works?
So far i've done a band adjustment, a tv adjustment, two fluid exchanges, one filter replacement, governor pressure sensor and solenoid replacement, and an output speed sensor replacement.... You seem rather knowledgeable, why would the limiter not work? and the actual throttle cable is a bit loose is there a way to tighten that? maybe the throttle and the tv cable need to be matched?
G
gallis95
maryland
Tried Tv adjustment again and it still doesnt work... someone help me.. TRUCK shifts at partial throttle but wide open throttle it doesnt... ive done a few adjustments but it doesnt make a difference.. truck drives like it has no limiter what can it be? HELPP!!!!
Merc225hp
NA
truck
gas
You have done all that work and it still does not shift at wot, and the fact it was driven without the spring off the tv cable tells me its time for a rebuild.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Is it slipping at all? How is it shifting under light throttle? What speed does it shift into OD and lock up at?
JMIMS37
