Husker4theSpurs
- Jun 8, 2020
- 20
- 2
- Location
- Papillion, NE
- 2020
- 3.0 EcoDiesel
Hello Ram Forum members!
I think I have my build figured out for ordering a Ram ... likely next year. Basically will be a Black Limited EcoDiesel, but one thing I'm kind of unsure about is the rim choice. I don't normally mind sticking with OEM rims on my vehicles, but I was thinking if I was considering trading out the stock rims I may as well just stick with the 20s if I'm going to replace them anyhow (save $2200 not getting the 22s). However, I'm not 100% certain I would change them out and find the 20s to look really small on the 5th Generation. If I'm going on looks alone I definitely prefer the 22s, but that's a pretty steep up-charge.
I like the idea of more sidewall versus the 22s but will it really matter that much ride-wise if I have air suspension? How large of a tire can a person go up to on the stock 20s and 22s without rubbing? All that being said, I think fuel economy is probably a higher consideration for me than some other people ... I know the difference between a 22 and 20 is minuscule in terms of fuel economy in the larger picture of things however. Plus a larger rim weighs more and the tire is wider so I suppose that makes fuel economy a hair lower as well.
I will likely be ordering this truck as I want the 3.21 rear end as I won't be hauling huge loads or towing a whole lot and think I'd appreciate the bump in fuel economy on road trips.
Would appreciate any input given this decision, but would for sure like to know:
- Maximum size tire that members are finding work with the 20s and the 22s. I do know that I will be getting all terrain tires at some point (yes, likely a minor fuel economy hit there too). I guess if I went with an aftermarket rim I could go with a larger tire than if sticking with OEM as well due to offset/backspacing.
Thanks for any thoughts you're willing to share!
