zone off road ?
sawbillslayer
so if I put the zone off road 2in. on my 2014 ram 1500 crew would that be all I need to level my truck ?
jbr
Long Island, NY
Depends on how much rake you currently have on your truck. Ever truck is built slightly different (rake varies). Take some measurements of front and rear wheel well (from ground up). May have to replace control arms because spacers are known to cause ball joints issues.
S
sawbillslayer
Its a 3 inch difference front to back. I didn't know if the zones solved the Control arms / ball joint issues.
scottyram
Ontario Canada
Highly recommend replacing the stock UCAs when doing a level. Stock arms are popping balljoints with any amount of lift.
DisturbedGator
I wonder if Ram will issue a TSB or recall for this problem. but if not too many people that are stock are blowing them than chances are slim.
