A little bit about the work that has gone into this (don't judge me for my OCD
Other than the obvious - plywood, painted, carpeted, LEDs (about 4'), here are some of the fun things:
I got a 12"x12" piece of perforated aluminum, cut it bent with my brake. I had to go really slow because it is so thick, kept it really hot and still ended up with some tiny stress fractures on the back. No big deal it is really strong still... Had I made a little less sharp of a bend, there would have no fractures. There is frosted Lexan behind the perforated pieces, to spread the light a little better and so you don't see the LED dots.
Then I beveled the edges and sanded it into a brushed look. I used some Q-tips in my drill and Mother's polish to polish inside each individual hole, so it was shiny and contrasting against the brushed surface.
The wire conduits were made from aluminum tubing that I bent and cut to fit, then polished them to a mirror finish. The ideas was that they reflect the light The blue sleeves are obviously automotive parts, but I felt it needed that little splash of color...
The back cover is just sheet metal that I cut, shaped and wrapped with the vinyl CF.
I removed the Arc logo, made that little aluminum backing for it, and then wrapped the underside in the CF as well. Being raised it allows the LEDs below to make a halo effect.
Also made those little aluminum shapes under the screws that hold the CF cover in place, because I learned a long time ago that vinyl wrap bunches up when you screw directly against it (even with a washer). The screw heads were polished with Mother's to a mirror finish...
