BradKnob
- Mar 12, 2014
- 1,382
- 395
- Location
- Prairieville, LA
- 2012
- 5.7 hemi
Yea, just easy on the gain and volume.
You got it right David.After an hour of reading and searching for diagrams, I think this the right way.
Please correct me if I am wrong.
I am trying to run at 2 ohm.
That's 2- 2ohm loads going to a mono amp which equates to 1ohm. Looks like your only ootions are 1 and 4 ohms
Edit: is that mono amp ur running?
Another edit: you put sk1200.4 in ur diagram. Thought u were running a 4 channel for a sec. That threw me off. 1 and 2 ohm are your options
This is what threw me off...
The .4 after sk1200 usually indicates a 4 channel amp. U have a 1 channel. The 2 sets of terminals is just for ease of installation when running 1 or more subs. If u hook both subs into the right + and - or left + and - or mix and match, it won't make any difference. They all sum into 1 channel.
I would prob run it at 1 ohm and just leave the gains and levels in the DSP down a good bit
Sorry, that was a typo... fixed.
If wired the way the diagram is, would it not make it 2 ohm??
Honestly, I am a little nervous after how much Nick warned me about these subs, I definitely don't want to send too much power to them...
DavidRam's Land of Audio Confusion. Now that's funny.
So there is no way to run 2 ohm unless I had a 2 channel amp?
Yes.....
Or a third MKIV!!! [emoji15]
