Headlights, why remove grill?
Dmopar74
Had this out and back in 5 minutes no prob!
Mineralram
Some remove the grill some dont, i never do its not needed
Sent from my SM-G900W8 using Tapatalk
CMil527
Old Bridge, NJ
2021 RAM 1500 LARAMIE-CC
yeah I realized after removing mine recently you could certainly get away without taking it off!
Tsbot
Did you upgrade to projectors? I have a 15 w halogen and would like either oem or aftermarket projectors.
Jmhm17
Massachusetts
5.7L HEMI
Given his grill and Park Sense sensors in the front bumper I'm betting he has a Laramie - so they are factory for him.
If your intent is to go to factory projectors to put HID's in them I would tell you to just get a retro fit from JJ. the stock projectos suck with HID's the only benifit is the LED strip. You could get OE projectors with retro fits and a harness but thats a lot of cash
Rzrman328
The treeline
I just like the extra space to work. Plus removing the grill is cake. 4 screws.
BlownGP
Houston/Baton Rouge
Yeah, I guess if you use a super long extension you wouldn't have to take the grill off.
What I have trouble with is the ******** tabs in the rear. Need a arm made of rubber to release them.
D
Dmopar74
I have the stock projectors. I just wanted to see what bulbs were in there factory. I might try some Sylvania zxe bulbs, I have em in my burb and love em.
Mineralram
Hid's are really bright in the factory projectors, i would like a set but not putting up with the problems associated with them so i just bought putco ion spark white bulbs for my lows and highs to match my opt7 led fog lights
KarL45
Western Slope, Colorado
2018 Ram Express quad cab 4x4
5.7 MDS
After fighting with the first one, the second one was quite easy. Found that the ball and socket had corroded making pulling it out very difficult. After a light spray of white grease on both ball and socket, then reinstalled. Tried it a second time and came out easily. The grease definitely helped. Having a huge grill guard and now having an aux. spare tire mount on the front, removing my grill would be really tough.
Jmhm17
Massachusetts
5.7L HEMI
Stock projector halogens are 9012 you will not find them in any aftermarket flavor or color as they are HIR's.. however you can modify a 9006. This is what people use for HID size on projector housings.
But be aware a 9006 halogen is not as bright as a HIR 9012. Unless you get an overpowered 9006.
SportyJames
Corpus Christi
2015 RAM 1500 Sport
Are you talking about the white tab that holds the light in the back of the housing?
Underarock13
Ram 2500 14
6.4 hemi
Because if you don't remove the grill when you start to screw the bottoms in you screw up your headlight adjustment which drives me nuts if they're not even.
BlownGP
Houston/Baton Rouge
Yeah, every time I'm putting my headlights back in and it takes me forever to find that white tab..lol
D
Dmopar74
The 2016 low beam is a 9005sl+, 1860 lumens with a 1000hr bulb life or some crazy life like that, and it's a 9005 base. 9005's are commonly rated at 1700 lumens, so one could use them but with a short life, say 100-300 hours. Now if we were to put a hir1 in there, we're up to 2350 lumens but again no color changes available.
SportyJames
Corpus Christi
2015 RAM 1500 Sport
You're going through the hole in the fender well?
Jmhm17
Massachusetts
5.7L HEMI
They changed the bulbs in the projectors?? :roflsquared:
