- Joined
- Nov 27, 2017
- Posts
- 727
- Reaction score
- 641
- Location
- NorCal
- Ram Year
- 2020 Limited CCSB
- Engine
- 6.7 Cummins
So I got the factory Mopar lights free from the dealer but didn’t have them install them as I didn’t want the factory method. Added a Curt #56584 harness between the 7 pin tow jack, spliced in a Blue Sea waterproof inline fuse and tapped power from that. Finding a factory ground point on the frame near the airbag helped a lot. I contemplated many methods and locations for a bed mounted switch but nothing really worked until I noticed the hole in the bed sidewall next to the tie down.
The hole just happened to measure out to 3/4” or there about. Dremeled back the spray in liner inside the hole and the Rigid waterproof switch fits like a glove. Used half of the factory light loom and the rest to make up the ground and switching connections. All connections are soldered, liquid taped in looms with friction tape at the important spots. When zip ******* looks factory installed. Installed the new Bedrug XLT Bed Mat too and it works great. Best thing is I can turn on the lights whenever without having to go to the cab and the bright switch makes sure I don’t forget to turn them off!
