Synthetic Oil
Oil of Choice
  • Castrol Syntec/Edge
    Votes: 236 8.5%
  • Royal Purple
    Votes: 327 11.8%
  • AMSOil
    Votes: 400 14.4%
  • Valvoline Synpower
    Votes: 160 5.8%
  • Mobil 1
    Votes: 994 35.8%
  • Other
    Votes: 662 23.8%
  • Total voters
    2,779
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
QSUD 5W30 is LSPI compliant so while it has more moly it has less of everything else.
PUP 5w30 has less moly but to my knowledge it has not changed the formula to be LSPI compliant (yet), the PP looks like it has changed though.
This QSUD analysis is from late 2017 but you get the idea.
full
We need to see the QSUD 5w50, I bet the add pack looks much different. With a cSt of 17.0 at 100c it’s something I want to run. Most likely sheer down into the 15’s; if the moly is at a respectable level I think this 5w50 is a player.
I believe QSUD is Gen2 now, new formula!
chrisbh17
I bet the qsud 5-50 is great for the mustang crowd!
Sent from my Nexus 6P using Tapatalk
GottaBeKD
CA
QSUD is on sale this week at Canadian tire. On for $29 regular $54 for 5L jug.
3 jugs is 15L which will cover 2 changes. Under $60 with filter is a win for me if it's as good as it sounds.
Still another 2 months away from next OCI.
Sent from my SM-G955W using Tapatalk
Man, I'm away for a few weeks and all of a sudden this thread is deep in QSUD...I love it! My Reb rolled over 50K miles yesterday and beginning its third round of QSUD 5W-30...all is well. On my last UOA, Blackstone said I could go 11.5k miles on the OCI, but I'm sticking to 10K (easier math!). My engine, which never ticked, is smooth and quiet...it did quite well on the trip between Texas and Colorado during the July 4th holiday; I even managed 19.5 mpg at one point on the return leg.
TXCOMT
The formula which we care about has got seriously better since the 2013 year. We should have a list of most improved oils, since we tend to not keep up with current info. QSUD would be high on the list imo. Better on almost ever line current versus 2013, tbn, moly, zinc, noack, etc.
U&A
2016 3500 SRW
6.4 HEMI
Spark plug change
A bit long but he does a good job with pointing out the few struggles you should expect to run into. Also a few pointers.
He also posted a link to the swivel socket extension he used. This is the same one that Corey suggested last year.
Thanks Corey[emoji847]. Got mine as soon as you mentioned it. Plug change happening this weekend. I’ll do my best at looking at the top of the piston on the front cylinders but I’m not gonna go out and buy camera.
Note that he DID NOT use anti-seize on the thread or dielectric grease on the coil boots. Or at least he did not show using it.
That is totally your call.
perfect timing, I'm in. never thought taking of tire.
looks very doable with that tool.
niagara
plus a 7$ mail in rebate and 20x points bought few jugs on sat.
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
Spark plug change
Yep, that swivel tool is a must. It’s definitely a Must Have tool for Hemi plugs.
Hemi395
Cape Cod MA
Spark plug change
Ha you're welcome [emoji16]
Thats Boosted Motorsports video and he's in southern California where there is no salt in the winter and only a moderate temperature change in the winter. IMO antiseize on spark plugs is a must if you live in the rust belt. Just a very light dab on the bottom of the threads. I have to do my plugs in the fall and I put antiseize on at 29k so I'll post some pics when I do them.
U&A
2016 3500 SRW
6.4 HEMI
Your Current miles?
I just broke 30,000.
U&A
2016 3500 SRW
6.4 HEMI
Just hit 57k this morning so I figure by fall I'll be around 58 or 59k...
Dont you have the NGK LZFR5C-11....?
16RamHemi
Western Maine
Hemi 5.7 Sport Crew
doing my plugs this weekend as well. im @ 74k miles. swivel socket, plug gapper and torque wrench should be here Wednesday. ngk laser iridium 92145 plugs are already here..im hoping i can get up into the engine bay like he did. with a 4" lift and rather short arms....reaching from a step ladder would suck. hoping plugs fix the shudder i feel ince in a while when shifting.
Hemi395
Cape Cod MA
U&A
2016 3500 SRW
6.4 HEMI
