Oem battery
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
Yes, I am aware of that. However, I am wondering if the charging voltage going into the battery might be different than those trucks that do not come with AGM.
My RAM is a 2017 and the OEM battery is not AGM
I worried about this also, I couldn't get the dealer even to tell me if I had ECM code for battery type sensing. So I said screw it and put one in anyway. I haven't boiled it yet - which would be the failure mode (overcharge - AGMs are more efficient so need a lower charge rate).
When I changed my battery out I asked the same question and I’ve been looking through settings for the IBS Intelligent Battery Sensor and found the ones applied to my 2016 1500 5.7 are the same as the 2016 2500 6.7 Cummins which tells me they’re probably the same across the board.
Marshall
Sk, Canada
2014 sport
I just looked at my build sheet as I have it scanned to my puter, I see 730amp battery, which is still in the truck , 14 sport, it has the performance hood, so that must help:)
One thing , it lists a ashtray light, funny , in all the years I have has this , never found a ashtray?
I have only 72km on the truck
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
What BCI Group Size is your OEM battery?
Jeepwalker
WI
2012 Reg Cab, 4x4
Duralast is made by Johnson Controls ...as is the Walmart Ram battery ...and Optima batteries. If you have a Menards near you they sell a Delco-branded large battery which has side and top posts (if that has any value to you)
HEMIMANN
Minneapolis, MN
Delco is JCI also. As is Interstate.
Since they moved from Milwaukee to Mexico, their quality went downhill. Research it.
I only buy East Penn, Odyssey, Trojan.
I don't have any trouble with these.
Jeepwalker
WI
2012 Reg Cab, 4x4
Delco is JCI also....
You know ...you're right. When I bought the Delco battery, it said made in Korea by Delkor. And there was some quality assurance data that looked pretty good. I just looked it up and it's a subsidiary of Johnson Controls. So, Thanks ...I stand corrected.
My main reason for buying it was the large size and dual-post feature which is was the only local battery (in stock) like it I could find. It's not in my Ram ...BTW (that's another JCI battery!).
I haven't had any problems with JCI batteries (nor Optimas) so that's ok with me. I used to work for JCI for many yrs (not in the battery division). When I worked for them I had all Optima batteries as an employee could buy them a lot cheaper ..he he.
HEMIMANN
Minneapolis, MN
np - it's impossible to keep up with all the takeovers. JCI was once one of the best. Not anymore, in the race to the bottom.
Look at Ram - "Stellantis"? Really?
Marshall
Sk, Canada
2014 sport
Code is BCNS, on sheet, 730amp maintenance free battery, just the standard one I guess, have not looked at the truck, cold and 60KM winds
Jeepwalker
WI
2012 Reg Cab, 4x4
Time will tell. People claim this quality is bad or that ...but in the case of batteries, there's a number of factors over 5 or 10 yrs that can contribute to battery life ...but how can you tell what's what unless ya kept laboratory-quality records of multiple batteries? (you can't)
I've had Optima's and L/A batteries which I didn't 'think' lasted as long as I thought they should, and a few that lasted way longer than I thought they should. Then again, some of those did go dead-dead ...more than a time or two over their life. They charged up, but that might have been part of the problem too. But I never kept track of which battery did what for how long and what time of year. So how do ya REALLY know??
HEMIMANN
Minneapolis, MN
You tell by reading reviews for a while before purchasing.
Jeepwalker
WI
2012 Reg Cab, 4x4
Some Interstates I think are also made by Exide (or used to be). Batteries are going to be made to specifications regardless if it's JCI battery or Exide. L/A battery production hasn't changed much in decades. It comes down to the cost to manufacture ....and scale. The cost of mfgr, they've had that as low as possible for years. Not much can change there.
The better and more expensive batteries like your Interstates and Motorcrafts, Platinum-level batteries will have:
-Thicker plates
-Better quality innards
-More internal support structure
-New (not recycled) lead
-New (not recycled) Acid
Spoiler alert: if you buy the cheapest, 2yr warranty battery off Facebook, you're not getting the same quality of battery that costs 25-60% more from Interstate or other places. But you guys know that...
w6pea
U.S.Marine Corps Veteran
San Diego, Mexifornia
2016 Ram 2500 "Laramie" 4x2 CC/LB SRW 6.7L CTD Leer 122 Campershell
6.7L IL6 Cummins Turbo Diesel
I went out to start my Ram 2500 and my JGC . Thought the JGC wouldn’t start. Surprise surprise it started send crank of the hemi engine. I went to start my Ram truck and all I got was click click . The bad thing is that I replaced the batteries in my truck in October. Stated great in October and November. Got carted away to the hospital in an ambulance. My wife doesn’t drive anymore so both the Ram Truck and the JGC (Jeep Grand Cherokee), both have new batteries so go figure
HEMIMANN
Minneapolis, MN
-Thicker plates
It comes down to quality control and environmental regulations.
Different Drummer
North East
Pentastar V6
More phantom loads in the RAM than the Jeep?
HEMIMANN
Minneapolis, MN
Yes - I couldn't remember the name of those. They were started by some guys from Odyssey, now Odyssey bought them, but they all kept their original marketing names. Both superb AGM batteries made in USA.
Batteries Plus carries X2, Autozone carries Odyssey.
Dr. Righteous
Jamestown TN
Seems with the OEM battery they live long and prosper or they die young.
The one in my '14 RAM laughs off freezing weather and is still going strong. The one in dad's '18 BigHorn went toes up the first cold snap we had this year winter.
HEMIMANN
Minneapolis, MN
Remember batteries have been outsourced in the 2000's.
Different Drummer
North East
Pentastar V6
LOL!! I was using the X2 to signify my agreeing with your post. All my batteries are either East Penn. or Odyssey. I have never used Trojan but know many who have used their FLA 6 volt batteries ( 2 in series ) and they love them. Ever since an OEM FLA battery in a very new BMW motorcycle I owned shorted and ****** on the frame and engine cover I have only purchased AGM batteries. Never looked back. However, I will be purchasing a LiFePO4 from Battle Born but that will be for a totally different application.
reddawg67
Winder ,Ga
well the oem battery failed me today !i guess 6 yrs aint bad ?think im gonna go with the advance diehard ?
