3rd gen
  1. J
    2008 6.7 Master cylinder hydro boost question
    I recently replaced the master cylinder on my (08 ram 2500 6.7 cummins Diesel) and I bleed all my lines and the master cylinder correctly (or so I think) and now my brake pedal is really stiff and when I'm trying to turn at the same time my power steering is locking up on me only when I'm...
  2. L
    2003 4.7 P0344...It Haunts Me.
    Hello, Everyone. Thank you in advance to anyone that responds and has insight on this issue. I also want to mention I've spend the last month researching daily for hours on what could be causing this P0344 code on my 03 Ram 1500 with the 4.7. Im no mechanic, but I'm broke so I do...
  3. L
    2005 Mirror - Driver Side dropping / lowering / angle change
    Sometime over the last year my Driver Side Mirror is changing angles after parking, or leaving it sit. I come out and the mirror and has dropped and all I can see is the pavement. There is not enough travel using the electric adjust to bring it up high enough, i have to roll down the window and...
  4. Y
    Mystery metal on trans drain plug, Help!
    Hey all, recently my 2004 5.9 with a fmvb 48re has been reluctant on the 1-2 shift and after getting it home it refused to 1-2 shift at all. I pulled the drain plug on the pan and while the fluid didn’t look great it wasn’t anything too unexpected for 25k miles on a fresh build but attached to...
  5. C
    Radiator coolant level
    Is the radiator in a 3rd gen 5.9 supposed to be filled to the brim when the engine is cold? the expansion tank is full and I just bled all the air out of the system using a coolant funnel kit. Took it for drive then checked the radiator after it cooled down it was about 1 to 2 inches below the...
  6. C
    Duraflex hood for 3rd gen 2500
    I just got a duraflex srt style hood for my 2007.5 2500. Hoping the body shop I’m going to knows what to do with it, they told me it would be no problem. Looks like I have to drill holes in it for the grill to be put on. Anyone have experience with this? Wondering if the latch holes line up or...
  7. C
    3rd gen front bumper air deflector / air dam / lower valance
    Wondering how this guy got this lower air deflector on the Laramie/sport style bumper. I think it’s the air deflector for the SXT and other models and he modified it to fit. If anyone has any experience with this please let me know. Want to add it my my bumper before I get the whole truck...
  8. B
    Anzo headlights not working 06
    https://shop.redline360.com/products/anzo-projector-headlights-dodge-ram-1500-06-08-2500-3500-06-09-w-led-halo-black-or-chrome-housing?currency=USD&variant=39350432333904&utm_source=bing&utm_medium=cpc&utm_campaign=Google%20Shopping&stkn=891961585efe&utm_term=bmax&msclkid=da8a1850e198132e7ecc7125...
  9. Cheeseburger93
    High beam issue
    Hello all, so on my 03 5.7 Hemi slt quad cab when I go to turn my high beams on I will get it clicked on, the blue high beam light on the dash is on but the high beams are of lower power than the low beams. I'm not sure where to look first cause I've checked fuses and they're okay and if itys a...
  10. jacoblane216
    Door Lock Rod Thread Pitch
    Having some custom door lock knobs made for my Rumble Bee and need the correct thread pitch, anyone here happen to know it? Because I can’t find it anywhere, Thanks in advance. Also this one is just a prototype, not as nice as the finished product will be.
  11. Blk_Shortie
    1/2 ton 4g bumper on 3g, thoughts?
    See a lot of the HD bumpers on 2g/3g's, havent been able to find this anywhere. Wondering if anyone has done it or what yall think, did a quick photoshop of it on my truck with referance
  12. S
    2007 Dodge Ram 1500 quad cab Hemi 5.7 Engine Bogs down when cruising at 1500 -1800 RPMs
    Hello, I have a 2007 Dodge Ram Hemi 5.7 and when I am driving the Engine bogs down when cruising at 1500 -1800 RPMs. From a stop the engine accelerates and shifts fine however once it gets to cruising speed around 1500-1800 rpms it starts bogging down but I can accelerate out of it. I just...
  13. uTweaker
    4th Gen Dash Into 3rd Gen
    Hey, First post on here! Currently in the middle of a interior swap Just wondering if anyone knows how to get the 4th gen 4wd switch to work in a 2003 5.9 I know that the headlight switch wont work unfortunately, but I heard the 4wd will. Just not sure what to do right now Or if anyone has...
  14. jacoblane216
    Lock Knobs and Column Shifter
    04’ Ram. I’ve dug around online countless times looking for some better looking aftermarket door lock knobs that actually fit well in the hole of the bezel but every single one I’ve found and thought might work are just too skinny and made for the more modern cars, so they just kinda rattle...
  15. W
    Fuel gauge stuck on full after pump replacement
    Hey everyone I know this has been talked about a couple of times but I cannot find any posts with the exact same scenario. My fuel pump went out a week ago. I opted for the bosch replacement. I didn't run into any particular issues during the install and went with the lifting the bed strategy...
  16. J
    2007 5.7 hemi fuel pump/sending unit
    Hello everyone, This is my first time posting here. This is going to be a long read but im in some dire need of help. A few days ago my truck died while driving. No warning, just boom. I scanned for codes and only have code for an o2 sensor that has been there for a year. I turned key and...
  17. C
    3rd gen to 4th gen door swap
    Hey, was curious if any one has done a door swap from late 3rd gen to 4th gen doors on 1500s, or if it's even possible. Any Input would be great!!
  18. jacoblane216
    2/4.5 or 3/5 kit?
    I’m planning on dropping it already at least 2/4.5 but would like just a tad more if there isn’t too much rubbing. The long term wheels that I’ll run are 22x10 on 305/45 nittos or toyos. I know the rear will have plenty of room but how much scrubbing at full lock turn should I expect from each...
  19. SthrnTruckr
    Power Wagon axle swap to DRW
    Question..I have a lifted 2005 power wagon. And I'm looking to go with the 5.13 gearing with bigger tires. Obviously, they don't make a 5.13 kit for the PW since the rear axle is a hybrid 10.5 AAM (11.5 shafts inside)... So my question is this: I found a good deal on an 11.5 AAM DRW from a 5th...
  20. jacoblane216
    Strange Electrical Gremlin
    Alright I’ve had enough I can’t take this surging power anymore. 2004 Ram 5.7 rwd, I’ve been having surging issues since I got this thing years ago after totaling my pristine white one, it’s weird it’ll surge for like the first 10 minutes of driving and if I’m going slower sometimes it’ll just...
  21. 3rdgenAdam
    Stalling issue
    2003 Ram 1500 4x4 5.9L magnum Truck starts right up idles great and smoothly, stalls 30 seconds 1 min a few mins after started. It will restart again right away but continues to stall, just dies, doesn’t chug or anything along those lines. Codes I’m getting….. p0031, p0037, p1495, p1765. I know...
  22. M
    Suspension questions for mega cab
    Hello! I have a 2008 ram 1500 megacab that I just picked up last month. I'm trying to figure out how to improve my ride but having a hard time telling if the current suspension is completely stock or not. I am attaching 3 pictures. One of what the front looks like, and 2 of the back. I'm...
  23. jacoblane216
    Rumble Bee production number plate
    Does anybody know of anyone making new production number plates for the special edition trucks(Rumble Bee, Daytona, GTX, SRT-10, SRT-10 Yellow Fever, etc.? I know you can find the dress up kit on 3rdstrike and I’ve actually already bought one for my Rumble Bee to replace the door panel bees and...
  24. S
    Beach wheeling
  25. I
    Aftermarket Headlights
    I have a set of aftermarket projector DRL headlights that are “plug and play” that come with a resistor and are supposed to plug straight in and work. Well here is the deal. I have plugged them up and the driver side light works and the passenger side doesn’t. They both work until I give the...
