air conditioning
  1. M
    2008 Dodge ram A/C stopped Working ?!?
    Hey, wondering if anyone knows abouts air conditioning on 2008 dodge ram TRX HEMI. It was working but was a bit inconsistent ice cold to cold enough, then just stopped it was blowing a bit of frost air put vents as well. But my line out of the bottom of my condenser is hot until halfway up my...
  2. BOSTONDAN1990
    HVAC Issue - air not changing when selecting different settings
    2014 Ram 1500 5.7 -- I'm having an issue when trying to select where air is coming out of (I.E selecting vents defrost and floors nothing changes) I changed out the 3 easy accessible blend doors (behind glove box and front of dash) and all seem to be working fine. when I turn the dial to select...
  3. A
    AC Compressor won’t turn on
    Hey all, Thought I would turn to the experts on some major trouble I’ve run into while recharging my A/C! I am finally recharging my AC after doing cam/lifters over the winter. Everything was going well until I was attempting to add the Freon when I could not get the compressor to turn on. I...
  4. G
    Close the recirculation vents w/o turning on the AC
    I have a 2022 Rebel and noticed that when the AC is off, the recirculation vent stays open, and when I press the recirculation vent button to close, the AC or the blower turns on. Is there a way to close the recirculation vents w/o the AC or blower turning on? Is this something a dealer can...
  5. U
    2022 Ram 1500 4X4 A/C
    Has anyone else noticed that the A/C in the new trucks doesn't blow as hard as the previous models? If so, is there a way to fix it? I have cleaned the cabin filters. The truck has 9,000 miles on it.
  6. C
    A/C fails on start
    2012 2500 Laramie with 6.7 Cummins A/C works great, BUT sometimes on hot days when I start the engine, the A/C isn't engaging the compressor. It happens with cold or hot engine. I have to turn the A/C off for about 1 minute and then turn it back on and it will operate normally. My guess is...
  7. A
    Air Condition Issue- Works Intermittently - 2003 Dodge Ram 1500 SLT
    Hi folks, I'm the owner of a 2003 Dodge Ram 1500 SLT and I'm having some issues with the air conditioning. Specifically, the air conditioning does work while I'm driving, but when I'm idling, it doesn't blow cold air. This issue started a few months ago, but now that it's summer time - it's...
  8. Handy Smurf
    Ram 1500 2020 found adhesive pad on floor near brake pedal where does it go
    Vehicle was in for service to ac. The expansion valve was bad. Got back and the ac is colder. I feel like it should be colder but I guess that's the best they can do. Anyway a couple days later I was sitting in vehicle and heard something drop to the floor under the instrument panel i...
  9. SND2010
    Strange A/C phenomenom
    I just purchased a very clean 2010 SLT Crew Cab. I was driving it home from the dealer (125 miles) and I noticed that when I was stopped or moving slowly in traffic the volume of air blown through the A/C ducts seemed normal and cool. However when I was at highway speeds (75) the volume of air...
  10. B
    A/C and radio not working
    Hey guys, 2013 1500, radio completely died today in middle of a song, ac stopped working at the same time, all fuses I’ve checked are fine, if I disconnect battery cable for a few minuets and reconnect, the radio flashes for a second then shuts back off. Anyone have any ideas? Thank you
  11. N
    My aircon is turning off on it's own, help
    So my 2015 Ram 1500 (Laramie) is having an air-conditioning problem. I just took the truck for a quick errand and tried to replicate the issue. Here is what happened: Turn on truck, wait for console to boot up, blast AC on full, after 5-10 seconds it cuts off. Not more air, no noises, nothing...
  12. S
    AC clutch replacement without losing pressure
    Hey guys, just thought I would share my clutch replacement experience with you. Hopefully it will help out someone else with the same problem. First thing was the diagnosis. The AC was not working, nor was the clutch engaging. Next step check the refrigerate and make sure there is pressure...
  13. H
    AC issue -- 2009 Dodge Ram 1500 Laramie
    Had my AC thermostat replaced back in April. Just within the last few days my AC started acting up. Any suggestions on what might be the issue? Here is what it is doing. Setting is on LOW with AC cooling button turned on. It will be blowing nice and cold at the proper speed and out the...
  14. A
    AC turned on full on start up and auto start
    2012 Ram Longhorn 6.7 Cummins I've been searching for months now on several sites but nowhere has answers even my local mechanic and dealer doesn't! My issue is, upon star up my fan is turned to high on the coldest setting with my AC on, for me that is an annoying problem giving that I live in...
  15. Drunken Hamster
    Problems with truck, looking for insight.
    Hey, guys, finally got around to posting this. There are several things wrong with my truck that I want to iron out, so I'll get right to it. -Got a P0071 the other day. Ambient Air Temp sensor. Dunno how this affects the truck, should I be worried? Would the fix be to just get a new sensor...
  16. M
    2018 Ram Air Conditioning Recharge
    Has anyone else had an issue or know why I am unable to attach an A/C R-134a recharging hose fitting to the low pressure port on my new 2018 Ram 3.6L V6? I bought it new and noticed this summer that the A/C is not performing as well as it should be - the output air is barely cooler than the...
  17. L
    Blower working intermittently
    I have a 14 Ram 1500 with the nav/alpine sound system. I've scoured the internet and can't quite seem to find the answer (or what I think is the answer) to my problem. I'm not sure if this is a wiring issue, a blower motor issue, or an infotainment issue. When I have my AC on, and ONLY when...
  18. I
    I NEED HELP WITH MY A/C 2001 dodge ram 1500 0200
    When I'm driving 60 or above accelerating my A/C turns off when accelerating it will turn blow air only when I stop accelerating.
  19. A
    Blower Motor Brand
    So my blower motor went out on my 11 1500. It is a Denso brand. I bought a Four Seasons to replace it, but is louder than sin. The only other brand I can find for manual temp control is TYC, but after my experience with the other, I would rather buy another Denso. The problem is that I can't...
  20. M
    Blower motor stays on after engine is off
    Ok I just bought a 2003 dodge ram 1500 slt 4.7l V8 magnum just under 120,000 miles on it. My issue is after I did the paperwork an got the keys I drove 20-30 mins to my insurance office an when I shut her off my blower stayed on it wasn't blowing cold nor hot air just like it was sucking air...
Carbary
