no codes
  1. L
    No crank no start
    Hello, I have my 2013 Ram 1500 4.7l have a no crank no start issue. So, backstory, I do landscaping on the side and have three yards on one street, two of which are next-door neighbors, but the houses are just about 2-3 blocks away from each other. Drove up to my first yard, did leaf clean up...
  2. tscarber
    No Codes, No Start
    Recently I have replaced the Cam / Lifters in my 2013 Ram 1500. I replaced cam, lifters, oil pump, water pump, sparkplugs, cam position sensor, VVT solenoid, cam phaser, timing chain & accessories. Upon start up the truck will not run. The truck will turn over with no issue but will not run. I...
  3. K
    2012 HD Stutter at highway speeds then runs rough until restart
    I have 89k miles on the truck, bought it used a little over a year ago. Mostly it sits until I need a manly vehicle but the van is down at the moment so the Ram is my daily driver now. A couple weeks ago I was driving up the interstate at speed about 30 minutes into my 45 minute drive when I...
  4. P
    $50 REWARD for solution - 97 Laramie 5.9 - DYING
    With the understanding this truck could be taken to a dealer and "possibly" get resolved, I am on this site precisely to avoid just that, so please do not suggest it yet again. This has been a nightmare for more than a year. I will pay $50 CASH to the first person that comes up with THE correct...
  5. P
    97 Ram 1500 Laramie 4x4 5.9L Keeps dying, NO CODES, No Warnings
    5/28/20 - I put this on dodgetalk.com, been reviewed 29 times in 48 hours, with zero (0) replies. Any help HERE? Thanks. This is about the 10th time this has happened. I am sick of this. I've gone through this forum and replaced everything suggested except the truck itself. I have replaced...
  6. K
    Check engine light but no related codes
    Hello. I just bought a 2016 Eco diesel in December with 38k miles on it. About a week ago, maybe 10 days now, my check engine light came on so I swung by an O'reillys to get the code read and their reader couldn't pull up any codes. It showed that the check engine light was lit up, but couldn't...
giantturkysub
