0-60 times
truckin151
2013 sport
Why in the hell are you still running a shorter tire size than what you actually have on the truck????? If you measured 33" for the tire height then change it to 33", you are still not getting accurate times/speeds. Our speedo's adjust based on tire size.
rocket
Licensed Dynacologist
Pennsylvania
was 2006
was a HEMI 5.7
This was done with 33's I recalculated my time by mile trial, I was a little off. So common sense tells me my tune was a little askewed. This time was not accurate, niether was the 33 measurement. As stated earlier I was close too 33 but not quite there. These tires are almost worn. i imagine with full thread they would still be a little short of 33's but really not by much.
Time for the mile was 1.03 At 65 mph. With a 33 inch. tire tune. I am dead on with the 32.5. 1 min at 60 mph.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Rocket,
I make my data runs using actual measured center of the wheel to a flat surface under the tire and multiply by two to get the diameter. This comes to just being short of measuring the tire with no wieght load. I use 93 octane and run 93 or 91 tune. I like the 93 tune fatten up to reduce KR. O/D off and gear selector in 2nd. (0-60 mph) I lightly hold the brake to keep the truck from moving and quickly roll the gas to the floor slipping the brake as the TC spikes. This gives me about a truck and half of spin and so far my best times. More brake make more spin. Slapping the gas makes more spin. Less brake doesn't drive into the TC as hard and also slows the times. It has taken me a lot of practice to maintain this fine line. Road surface and temperature also screws up the routine. Just practice some and your times will come down. Good luck..
rocket
Pennsylvania
was 2006
was a HEMI 5.7
So rf uses the images on loan?Wtf. Oh well 7.61 was my best time.I'm on a 91 tune, Gonna check on those tips red, I pretty much did that,just not as heavy on the gas peddle. Kind a hard where I launch. I'm kinda coming off an entrance ramp. at a dead stop, just not perfectly straight. Gotta wait for traffic and lookout for cops. But we will see I'm gonna do this and another launch with a power wire. Till then
rocket
Pennsylvania
was 2006
was a HEMI 5.7
Our speedo's are set according too tire size from the factory. i dunno about self adjusting speedo's If thats what you refered to. but I was able to adjust with the sc. Besides mile markings I'm gonna put it up too a satelite and adjust further. Those suckers are dead nuts with time and distance.
Redtruck-VA
Virginia
Red has a new best time.
0-60 mph - 5.67
1/8 - 8.86 -75 mph
1/4 - 14.16 - 91 mph
I'm going to set my announciator to for a shift point to tighten my manual 2-3 shift. As I am currently stuck with a stock rev limiter. Man , I need a custom tune! Added some fuel to kill some kr. But basically all is good for where I am at mod wise.
http://img838.imageshack.us/i/dsc00463.jpg/
Redtruck-VA
Virginia
Finally got the A/F kit installed. This took me six hours, what a pain in the a$$. I used a **** that was on the inlet of my Cat. Didn't use anti-sieze, my bad and had to work to save the threads. Routed the wires which took me a couple tries to get right. Also added a LED light to indicate when the eFan was running. Don't know why it took me so long just a lot of fussing around getting everything the way I wanted it.
truckin151
2013 sport
When we got mine installed we did got everything welded in at the same time as we did the cats on the headers. Only took about an hour to do the wiring and get it all up and running after that.
Now for the real test of all the fuel you've been adding, go take it out for a WOT run and see where that AFR is at.
Redtruck-VA
Virginia
Well guys, the truck is running better than ever. Idle is reading 14.5 at WOT I'm reading 11.00. The 9r06 Crom feels really good with the fuel added as I previously stated. The truck is a blast to drive. Off throttle while coasting I read 14.7. Give me some input..
truckin151
2013 sport
WOT you should be at 12.00 or really close to it. So you are running rich
Too rich at wot. Try pulling some of the fuel you added and do another run. Like truckin said, you should be shooting for around 12 at wot.
Bad Habit
Land O Lakes
Modded 4.7l
will get new times up soon...been real busy and the gears are broke in...now for trans tune....i just gotta find time to sit down log my stuff and enter new stuff...
Redtruck-VA
Virginia
Ok, this is the information I need. I'll do some adjustments and get back to you with some runs. Just finished my LED (eFan) light. Starting to cool down a little.
Thanks,
Bad Habit
Land O Lakes
Modded 4.7l
got mine at radioshack for 1.99 i went with red and on my dash as i dont have a pod pillar yet and when i do ill put it up there and something in its place....
Hell, for two bucks I pretty much have to do it.
Bad Habit
Land O Lakes
Modded 4.7l
just run a wire and "T" tap to the power side of the fan to the led and ground it, it comes on when the fan does....
Redtruck-VA
Virginia
Yep, got it from RS for something like $2. The first one died within 5 minutes. It is a 12vdc led, but the guy at RS said the problem is the truck may go as high as 14.5 vdc and can blow the led. Bought a new led and used a 220 ohm resistor inline and so far no problem. My controler has a spade for Motor which is hot when the motor runs. I connected to that.
ramhunter9
P-Star Jeep Wrangler
Well as some may know i got me a 3865 SC . I have to burn threw the 87oct before i use the performance tune .
So on the 87 tune , with my shift schedule and TQ adjusted on a 8k plus pound truck .... I was shocked .....
0-60 in 10.11 first ever run .... i bet i can beat that ..and this was on 87 TUNE !!! bet performance tune will be awesome
