09 1500 4.7
lindeevincent
If I could put a Cummins /trannie along with 2500-3500 rear end in my 09 1500 4x4 would it work nicest truck I've had but would like bigger
MADDOG
Living in a Firepit
Your 1/2 frame and suspension won't hold up under the weight of that Cummins. They weren't designed to.
You'd be better off getting a 2500 with the Cummins package.
Wahrsuul
Central S.C.
I somehow doubt that the Cummins is so much heavier that it would collapse the frame. I can see that you'd probably need new springs up front.
It's been done on 3rd gen 1500s, so I'd think it could be done on a 4th gen. But how much are you willing to spend? Would likely be cheaper to go with an Eco Diesel.
And apparently it's been done to a 4th Gen as well:
Ramtruck16
Blue Springs Mo
Not to mention trying to get all the electrics and body modules to work with the diesel setup, this type of swap seems prohibitively expensive to me.. just get a 2500 with want you want and be done with it.. much cheaper
Wahrsuul
Central S.C.
I don't agree that a 2500 is the answer either, I couldn't own one at the moment. The ride is far too harsh for a daily driver, and I can't afford 2 trucks. Besides, putting a Cummins in is no different than guys building 600+ hp Hemi's. Just a different kind of mod.
Ramtruck16
Blue Springs Mo
My 09 2500 was a great truck but would beat you to death on bad roads and it wasnt practical for me to use it as a DD as it only got 12-17 mpg which isn't the best considering i had to travel 50-60 a couple times a week.
My 16' 1500 is a much smoother ride and i can get up to 23 mpg if im easy on the throttle. Plus i can still tow a trailer if i need to.
