1/4 mile gears with 8speed tranny?
Josh22855
Building a 397 stroker engine with a D1sc procharger in a 2016 single cab ram 1500... My previous truck had 3.21 gears in it and I would finish the 1/4 mile in the top of 5th gear. Would 3.92 gears be optimal for this build or should i consider something else?
Any help is appreciated.
Ohio5pt7
Ohio
Side note still got that cam? Sent you a nother email not sure if you got it.
Sent from my KYOCERA-E6920 using Tapatalk
Ohio5pt7
Ohio
I would honestly stick with the 3.21 if you finished at the top of 5th 3.92s is just another shift. And dropping tire size can give you the same effect and reduces rotating mass
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Think wild one went to 3.55 from 3.21 and said if he had to do over would have stayed with the 3.21
https://www.ramforum.com/threads/3-...time-my-5-000-mile-review.91118/#post-1371472
