#1 missfire driving me crazy
acercracer
kingsville mo
07 ram 5.7 hemi
#1 missfire, plugs are wet with fuel
did compression and leakdown test, both good
new coil and plugs, also moved the new coil, didnt follow
swapped injectors, didnt follow
pulled valve cover, all rockers and pushrods tight, no broken valve springs. all open and close the same
checked coil signal with test light, pulsing like it should.
new cam sensor and crank sensor
No noise, no tick
any ideas would be appreciated, next step is to replace ecm
