17" rims
OntarioRam
1998 Ram 1500
3.9 v6
I've got 16" rims on my truck. I was wondering if anyone has made the switch to 17" rims. If so, will any 17" stock dodge rim with 5 studs fit?
tommyboi87
houma louisiana
5.2 Magnum
I think all rams except Cummins have the same pattern. Might need spacers for front wheels to get over the grease cap.
Sent from my SAMSUNG-SM-G925A using Tapatalk
Padilen
Sorry
I didn't see OPs post.
So I deleted my comment.
tommyboi87
houma louisiana
5.2 Magnum
Well 1500 are the same? I've got 20's from a 13 in my shed that fit. And I used to have 03-04 20's.
Padilen
I did a quick check its 5 on 5.5 for 1500's all years I saw.
Offset is the same on same chart.
O
OntarioRam
1998 Ram 1500
3.9 v6
Where I live, we get a lot of snow, so I'm thinking an extra inch or two will make a lot of difference in terms of clearance. And I think 17" will offer a better ride than 16" rims too.
Merc225hp
NA
truck
gas
Say what now??? Extra clearance from 17 wheels sorry no on both accounts.
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
I made the switch from stock 16s to stock 17s
O
OntarioRam
1998 Ram 1500
3.9 v6
Wouldn't 17" rims have an inch more diameter than 16" rims, and hence lift the truck 1' higher?
And I thought that larger tires offer a better ride, especially on bumpy roads like we have in Canada.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
No....Once you go up in a wheel size, the aspect ratio on the tire goes down. So say you're going from a 265-75/R16 wheel and tire to a 265-70/17 wheel and tire.....the size will be same within about a quarter inch.
So, the 17 inch tire will have less sidewall than the 16 inch tire.
O
OntarioRam
1998 Ram 1500
3.9 v6
I didn't know that the aspect ratio generally goes down with larger tires. I come from motorcycles, so I'm learning more everyday about trucks. Thanks.
BBartow
New Port Richey, Florida
5.9L Magnum
Its because the second number is the % of sidewall compared to the width of the tire. Bigger wheels means less sidewall compared to the same size tire with a smaller wheel.
